Ok, I’ve looked all over and apparently I have bad searching skills or it doesn’t exist.
I’m looking for a way to charge different prices for different colors of the same material. I’ve seen other Hubs that have figured this out, but I cannot for the life of me find out how.
Example: ABS - Black (Normal Price), Orange (increased charge), etc
I don’t think this would be possible without splitting up the material per colour. The colours are the first thing you set per material, so I would guess each colour would need to be a separate material.
Steve
Just Duplicate the Material to the same so you got two blocks of pla. Set different colors for each block and different prices.
Thanks… working through the very interesting way the system organizes data. I don’t mind having to create multiple Material sets with the same name, however it would be much better if you could organize them more easily. If you already have material set up like PLA, ABS, Nylon and duplicate or add another PLA, it gets put at the bottom instead of under the existing PLA. So for now the only way to correct that is to delete the other materials and then manually add everything back in the organization you want.
