i got my flash forge finder yesterday and i am very new to 3d printing, but now my filament is not extruding
i am using PLA at 220 c
what should i do???
I have tested flashforge finder, too and was very satisfied.
Are you able to make a video? Is the extruder motor running?
not really, but when i load the filament, about 2 inchs down it just completely stops and i have no idea on how to check if i can take the casing of the nozzle off so i can clean it.
i wouldn’t take off the the extruder case. I will advise you to take a thin wire and clean the nozzle. Have you check the nozzle temperature with a thermometer?
no i will do both of them now and should o go in from the top with the thin wire or the bottom?
we found that the PLA gets brittle in the bowden tubes area after a long print
so we simply reload filament take out the brittle area reload and start printing
