Anyone have an idea how to reverse axis for FFCP in firmware? I just changed my stepper drivers which require me to reverse axis in firmware. What is the best way to flash this?
Hi.
The simplest solution is to swap the red and yellow cable on the mainboard stepper motor connector.
/Magnus
If the swapping wires doesn’t help then I know you can definitely do it in simplify 3d settings, but I have never noticed it in the stanear flashprint firmware/slicer. Hope you sort the problem
While you can reverse it in firmware (see sailfish manual) it is typically not the procedure to go about doing this.
Almost all slicers have the ability to reverse the direction in the machine settings.
Thanks! I ended up reversing the wires which worked out great.
