I would like to get a file printed by tomorrow 2pm (the least). I know it is a very short dead line but it is my last back-up plan. Does anyone know a good printer location in the region of Brussels who could do the job by tomorrow? I contacted a few printer locations but I can only contact 5 people a day. Which is by far not enough when I can not take the risk having it not done. The models should be printed in an off-white colour. Another very important requirement for the print is that is has to be able to float in soup. What material should i look for so the used material can float and not get damaged in soup?
Thank you for your time.
Kind regards,
Dimitri Hatjipemu
Caviar Content Brussels
Luuk
Hey @DimitriHatjipem,
have you tried with https://www.3dhubs.com/brussels/hubs/laurents-officewar? If you want to reach out to more printer owners you can use ‘get a quote from this hub’, instead of ‘contact this hub’.
Good luck!
IDD3D
hello
I m from hoegaarden, 35 km from brussel, i need to have the file still to be sure that i can do it for tomorrow
daniel
Go ahaed and request a print on DaveMoi’s hub in Vilvoorde Hof ten voordestraat. If I can print it by tonight Inwill do so. Note that you will need to pick it up tonight as well as I’m not available tomorrow.
feel free to contact me if you have any other questions.
Kind regards,
David
The main problem I see is the color. Warm/Broken/Off/Perl white are colors mainly available in PLA and not so easy to find. Also, I think PLA ain’t the best because it start softening around 50°c.
But if somebody have the filament (in abs or hips?) and not the time, maybe there is a combined solution
Hi David, thanks for your comment. In the future, can you please use a link to your Hub profile as means of contact? …at least until we add clickable user profiles, which should happen soon
Cheers
Hey @DimitriHatjipem, did you get your print ready on time?
