hello, just a quick question :
after updating my stock A8 to skynet3D version 2.3.2 with the correct configuration profile after autohome the display shows: X -33 Y -10 Z 0 Err: Too far ! do you perhaps have an idea what the issue is …? thnxs in advance
Do you use an Autolevel Sensor or the Standard Switch? This Error can appear if you use the Configuration made for Autolevel but use the standard switch. Since the Configuration has an Z-Offset of 5mm as Standard, it moves down, hits the switch and then spits out an Error because it cant move down further.
If not you can try to perform one Configuration Save under Control->Save Memory on the Printer or an M500 over a Terminal.
