Juck88
Hi Everyone,
I purchased a kossel delta printer kit a few months back and finally after a few bumps, faulty board and PSU, I have it working… sort of. The results of the G29 shows (see attached) that the bed is sloping, I believe this indicates that the end stops are not level. The carriages have screws inset into the top which trip the end ends stops, this allows for fine-tuning. I would like physically adjust the screws to better calibrate the printer. Would I be correct in assuming that after homing the machine (G28) each carriage is then retracted/positioned lower by an equal amount, therefore if each end stop were truely level the carriages would also be level?
YUMI3D
Not necessarily, just define one calibration point directly in front of each tower and fine tune the adjustment screws until all 3 are on the same height after homing.
And be careful with the hole autoclaibration, that works only well after you have it 90% perfectly leveled manually and even then the definitions are really weird. I have given up on it for the moment until marlin gets it to work. btw which firmware are you using?
Juck88
Thanks jk3dtek & Yumi3D.
I calibrated the end stops using the method Yumi3D suggested and the adjusted the Delta_radius to fix the curvature. After printing a test 10ml cube it appears I still need to adjust the DELTA_DIAGONAL_ROD, the printed cube has the following measurements X10.36 Y9.86 Z9.78. Is there a better way to calibrate the diagonal?
I’m not sure what firmware I’m using, the Arduino 1.65 sketch came with the printer, it’s titled Marlin.
