can i call you or you call me so that we can talk about this? i am between classes and need to get this resolved ASAP.
my phone number is 440-313-7964.
GIFT3D
Hey Emily,
What is the problem you have. I may be able to help you out if you let me know.
I have these prints that are on the larger side and was wondering if you would be able to accommodate for them or if you know of any other hubs that would be able to print them.
Here are the dimensions of the models:
16.7 x 15.9 x 5.4 cm
24.6 x 17.3 x 6.1cm
20.1 x 15.2 x 6 cm
Thanks
GIFT3D
Apologies for the delayed reply. What I would suggest is that you click the red ‘3D PRINT’ button at the top of the page. This will allow you to start an order. I’m not sure but when you add your file it should restrict the hubs to those that have the correct sized printers. If not use the sort by distance tool which will order the hubs closest to you. Just make sure the location is correct. Then check the printers to see if they are the correct size. Once your ready just send an order and the bphub will tell you if they are able to do the order. Most orders should get to you within a week, or quicker.
Hope this helps
Hey @eskinny, you have landed on the 3D Hubs forum, Talk, at the moment. I see that you’ve recently started 2 enquiries, with @Titan_Robotics and @Perry_1. I’ve tagged them both here, so they can get back to you. Otherwise, feel free to refer to the order link you have received, after placing these 2 orders. Hope this helps.
Thanks for the help, @GIFT3D!
GIFT3D
6
No problem. I always happy to help others
