Hi Guys, I wanted to show you my largest print of 2014.
Build up from 100 pieces printed on two Ultimaker 2 and one Sharebot Next Generation.
The total print time is about 1600 hours and the tower weights 20.5 kg.
Its dimensions are 1900 x 900 x 900 mm.
The largest piece has a print time of 50 hours.
You can find my full post in German (and use Google Translator maybe or only have a look at the images and videos) on https://3drucken.ch/2015/01/grosser-eiffelturm-in-100-teilen.html.
Feel free to share your thoughts.
Gregor
This is awesome! Did you glue it together or what? I really like the different colors.
Hi Alex, thank you! Yes I glued it together with epoxys UHU Schnellfest and UHU 300 Endfest. Let it be 5 parts (blue section 1, white section 2, white/red section 3, red section 4 and the tip as 5) plus the reeling at first platform.
Hi Gregor (@3D_Luetolf) What where the difference you encountered between the Ultimakers and the Sharebot?
Ultimaker 2 is faster and more precise, Sharebot is more reliable and the direct drive using 1.75 mm is much better than the bowden 3 mm at the Ultimaker 2.
