How long should it take for a Flashforge Dreamer to return to printing after being paused? It’s been half an hour and it still just says “Exiting Pause”. Thanks.
Hi, It might be related to temperature issues. So , please check platform and nozzle temperatures and compare them with set values.
TB3D
There is no wait time other than what it takes to heat up the extruder and bed to temp which depending on how long you had it paused might be a few seconds or maybe max a min or 2
Based on what you’ve said, it appears that the platform was at 70 ˚C and didn’t want to cool down to what I had set it to, which was 30 ˚C.
Sometimes there are issues like that in Dreamer. But after shutting down and re-open the on-off switch there should be no issues at all. In your case the platform shouldn’t have reached that 70 degree value , because you set it 30 degree. Please check pre-heat value. I think that you are pre-heating your platform before printing and the set value for pre-heat is 70 degree. Set the pre-heat value at 30 degree or select it as “off”. Maybe that helps.
Happy printing
