Hi everybody !!!
Does a 2200 spool fit on a replicator 2 - 1st Gen ?
Can someone test it please ?
Most likely the spool holder isn’t designed for 2,2kg spools and might even break. You could either print a spool holder from Thingiverse.com youmagine.com or any other website, otherwise you can let the spoil sit on your table, while some kinds of blocks or anything similar stops the spool from rolling off the table. Cheers, Marius Breuer
Hi Marius,
Thanks for the reply, This sounds a useful solution.
But i was more thinking of the dimensions of the spool.
I think the spool is to big and will hit the table.
The holder I use from thingiverse should be no problem.
Thanks for your reply
The spool has an outside diameter of 300mm and a thickness of 100mm. The inner hole is 55mm across
Great,
Thanks !!
Nice community effort, guys :slight_smile: Love it!
