I have built a delta based around richraps 3DR. I have it homing fine (G28) but it will not move after that? The Z position updates but the printer does not move. Can anyone suggest anything?
I have built a few printers but neither were a delta and this time round I wanted more of a challenge and well… here I am!?
I have attached my configuration.h file.
Thanks in advance.
  • Configuration.h
  • Basic settings such as:
    • Type of electronics
    • Type of temperature sensor
    • Printer geometry
    • Endstop configuration
    • LCD controller
    • Extra features
  • Advanced settings can be found in Configuration_adv.h
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
#define CONFIGURATION_H_VERSION 010100
//============================= Getting Started =============================
//============================= DELTA Printer ===============================
// For Delta printers start with one of the configuration files in the
// example_configurations/delta directory and customize for your machine.
//============================= SCARA Printer ===============================
// For a Scara printer replace the configuration files with the files in the
// example_configurations/SCARA directory.
// @section info
// User-specified version info of this build to display in [Pronterface, etc] terminal window during
// startup. Implementation of an idea by Prof Braino to inform user that any changes made to this
// build by the user have been successfully uploaded into firmware.
#define STRING_CONFIG_H_AUTHOR “(oxivanisher)” // Who made the changes.
#define SHOW_BOOTSCREEN
#define STRING_SPLASH_LINE1 SHORT_BUILD_VERSION // will be shown during bootup in line 1
#define STRING_SPLASH_LINE2 WEBSITE_URL // will be shown during bootup in line 2
// *** VENDORS PLEASE READ *****************************************************
// Marlin now allow you to have a vendor boot image to be displayed on machine
// start. When SHOW_CUSTOM_BOOTSCREEN is defined Marlin will first show your
// custom boot image and then the default Marlin boot image is shown.
// We suggest for you to take advantage of this new feature and keep the Marlin
// boot image unmodified. For an example have a look at the bq Hephestos 2
// example configuration folder.
//#define SHOW_CUSTOM_BOOTSCREEN
// @section machine
  • Select which serial port on the board will be used for communication with the host.
  • This allows the connection of wireless adapters (for instance) to non-default port pins.
  • Serial port 0 is always used by the Arduino bootloader regardless of this setting.
  • :[0, 1, 2, 3, 4, 5, 6, 7]
    #define SERIAL_PORT 0
  • This setting determines the communication speed of the printer.
  • 250000 works in most cases, but you might try a lower speed if
  • you commonly experience drop-outs during host printing.
  • :[2400, 9600, 19200, 38400, 57600, 115200, 250000]
    #define BAUDRATE 250000
// Enable the Bluetooth serial interface on AT90USB devices
//#define BLUETOOTH
// The following define selects which electronics board you have.
// Please choose the name from boards.h that matches your setup
#ifndef MOTHERBOARD
#define MOTHERBOARD 80
#endif
// Optional custom name for your RepStrap or other custom machine
// Displayed in the LCD “Ready” message
#define CUSTOM_MACHINE_NAME “3DR J.LAWES”
// Define this to set a unique identifier for this printer, (Used by some programs to differentiate between machines)
// You can use an online service to generate a random UUID. (eg Online UUID Generator Tool)
//#define MACHINE_UUID “00000000-0000-0000-0000-000000000000”
// This defines the number of extruders
// :[1, 2, 3, 4, 5]
#define EXTRUDERS 1
// For Cyclops or any “multi-extruder” that shares a single nozzle.
//#define SINGLENOZZLE
// A dual extruder that uses a single stepper motor
// Don’t forget to set SSDE_SERVO_ANGLES and HOTEND_OFFSET_X/Y/Z
//#define SWITCHING_EXTRUDER
#if ENABLED(SWITCHING_EXTRUDER)
#define SWITCHING_EXTRUDER_SERVO_NR 0
#define SWITCHING_EXTRUDER_SERVO_ANGLES { 0, 90 } // Angles for E0, E1
//#define HOTEND_OFFSET_Z {0.0, 0.0}
#endif
  • “Mixing Extruder”
    • Adds a new code, M165, to set the current mix factors.
    • Extends the stepping routines to move multiple steppers in proportion to the mix.
    • Optional support for Repetier Firmware M163, M164, and virtual extruder.
    • This implementation supports only a single extruder.
    • Enable DIRECT_MIXING_IN_G1 for Pia Taubert’s reference implementation
      //#define MIXING_EXTRUDER
      #if ENABLED(MIXING_EXTRUDER)
      #define MIXING_STEPPERS 2 // Number of steppers in your mixing extruder
      #define MIXING_VIRTUAL_TOOLS 16 // Use the Virtual Tool method with M163 and M164
      //#define DIRECT_MIXING_IN_G1 // Allow ABCDHI mix factors in G1 movement commands
      #endif
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
//#define HOTEND_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
//#define HOTEND_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis
  • Select your power supply here. Use 0 if you haven’t connected the PS_ON_PIN
  • 0 = No Power Switch
  • 1 = ATX
  • 2 = X-Box 360 203Watts (the blue wire connected to PS_ON and the red wire to VCC)
  • :{ 0:‘No power switch’, 1:‘ATX’, 2:‘X-Box 360’ }
    #define POWER_SUPPLY 1
#if POWER_SUPPLY > 0
// Enable this option to leave the PSU off at startup.
// Power to steppers and heaters will need to be turned on with M80.
#define PS_DEFAULT_OFF
#endif
// @section temperature
//============================= Thermal Settings ============================
  • –NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table
  • Temperature sensors available:
  • -3 : thermocouple with MAX31855 (only for sensor 0)
  • -2 : thermocouple with MAX6675 (only for sensor 0)
  • -1 : thermocouple with AD595
  • 0 : not used
  • 1 : 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
  • 2 : 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
  • 3 : Mendel-parts thermistor (4.7k pullup)
  • 4 : 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
  • 5 : 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup)
  • 6 : 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
  • 7 : 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
  • 71 : 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup)
  • 8 : 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
  • 9 : 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
  • 10 : 100k RS thermistor 198-961 (4.7k pullup)
  • 11 : 100k beta 3950 1% thermistor (4.7k pullup)
  • 12 : 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed)
  • 13 : 100k Hisens 3950 1% up to 300°C for hotend "Simple ONE " & "Hotend “All In ONE”
  • 20 : the PT100 circuit found in the Ultimainboard V2.x
  • 60 : 100k Maker’s Tool Works Kapton Bed Thermistor beta=3950
  • 66 : 4.7M High Temperature thermistor from Dyze Design
  • 70 : the 100K thermistor found in the bq Hephestos 2
  • 75 : 100k Generic Silicon Heat Pad with NTC 100K MGB18-104F39050L32 thermistor
  •   1k ohm pullup tables - This is atypical, and requires changing out the 4.7k pullup for 1k.
  •                          (but gives greater accuracy and more stable PID)
  • 51 : 100k thermistor - EPCOS (1k pullup)
  • 52 : 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
  • 55 : 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup)
  • 1047 : Pt1000 with 4k7 pullup
  • 1010 : Pt1000 with 1k pullup (non standard)
  • 147 : Pt100 with 4k7 pullup
  • 110 : Pt100 with 1k pullup (non standard)
  •     Use these for Testing or Development purposes. NEVER for production machine.
  • 998 : Dummy Table that ALWAYS reads 25°C or the temperature defined below.
  • 999 : Dummy Table that ALWAYS reads 100°C or the temperature defined below.
  • :{ ‘0’: “Not used”, ‘1’:“100k / 4.7k - EPCOS”, ‘2’:“200k / 4.7k - ATC Semitec 204GT-2”, ‘3’:“Mendel-parts / 4.7k”, ‘4’:“10k !! do not use for a hotend. Bad resolution at high temp. !!”, ‘5’:“100K / 4.7k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)”, ‘6’:“100k / 4.7k EPCOS - Not as accurate as Table 1”, ‘7’:“100k / 4.7k Honeywell 135-104LAG-J01”, ‘8’:“100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT”, ‘9’:“100k / 4.7k GE Sensing AL03006-58.2K-97-G1”, ‘10’:“100k / 4.7k RS 198-961”, ‘11’:“100k / 4.7k beta 3950 1%”, ‘12’:“100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT (calibrated for Makibox hot bed)”, ‘13’:“100k Hisens 3950 1% up to 300°C for hotend 'Simple ONE ’ & hotend ‘All In ONE’”, ‘20’:“PT100 (Ultimainboard V2.x)”, ‘51’:“100k / 1k - EPCOS”, ‘52’:“200k / 1k - ATC Semitec 204GT-2”, ‘55’:“100k / 1k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)”, ‘60’:“100k Maker’s Tool Works Kapton Bed Thermistor beta=3950”, ‘66’:“Dyze Design 4.7M High Temperature thermistor”, ‘70’:“the 100K thermistor found in the bq Hephestos 2”, ‘71’:“100k / 4.7k Honeywell 135-104LAF-J01”, ‘147’:“Pt100 / 4.7k”, ‘1047’:“Pt1000 / 4.7k”, ‘110’:“Pt100 / 1k (non-standard)”, ‘1010’:“Pt1000 / 1k (non standard)”, ‘-3’:“Thermocouple + MAX31855 (only for sensor 0)”, ‘-2’:“Thermocouple + MAX6675 (only for sensor 0)”, ‘-1’:“Thermocouple + AD595”,‘998’:“Dummy 1”, ‘999’:“Dummy 2” }
    #define TEMP_SENSOR_0 1
    #define TEMP_SENSOR_1 0
    #define TEMP_SENSOR_2 0
    #define TEMP_SENSOR_3 0
    #define TEMP_SENSOR_4 0
    #define TEMP_SENSOR_BED 0
// Dummy thermistor constant temperature readings, for use with 998 and 999
#define DUMMY_THERMISTOR_998_VALUE 25
#define DUMMY_THERMISTOR_999_VALUE 100
// Use temp sensor 1 as a redundant sensor with sensor 0. If the readings
// from the two sensors differ too much the print will be aborted.
//#define TEMP_SENSOR_1_AS_REDUNDANT
#define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10
// Extruder temperature must be close to target for this long before M109 returns success
#define TEMP_RESIDENCY_TIME 10 // (seconds)
#define TEMP_HYSTERESIS 3 // (degC) range of +/- temperatures considered “close” to the target one
#define TEMP_WINDOW 1 // (degC) Window around target to start the residency timer x degC early.
// Bed temperature must be close to target for this long before M190 returns success
#define TEMP_BED_RESIDENCY_TIME 0 // (seconds)
#define TEMP_BED_HYSTERESIS 3 // (degC) range of +/- temperatures considered “close” to the target one
#define TEMP_BED_WINDOW 1 // (degC) Window around target to start the residency timer x degC early.
// The minimal temperature defines the temperature below which the heater will not be enabled It is used
// to check that the wiring to the thermistor is not broken.
// Otherwise this would lead to the heater being powered on all the time.
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 5
#define HEATER_2_MINTEMP 5
#define HEATER_3_MINTEMP 5
#define HEATER_4_MINTEMP 5
#define BED_MINTEMP 5
// When temperature exceeds max temp, your heater will be switched off.
// This feature exists to protect your hotend from overheating accidentally, but NOT from thermistor short/failure!
// You should use MINTEMP for thermistor short/failure protection.
#define HEATER_0_MAXTEMP 275
#define HEATER_1_MAXTEMP 275
#define HEATER_2_MAXTEMP 275
#define HEATER_3_MAXTEMP 275
#define HEATER_4_MAXTEMP 275
#define BED_MAXTEMP 150
//============================= PID Settings ================================
// PID Tuning Guide here: PID Tuning - RepRap
// Comment the following line to disable PID and enable bang-bang.
#define PIDTEMP
#define BANG_MAX 255 // limits current to nozzle while in bang-bang mode; 255=full current
#define PID_MAX BANG_MAX // limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current
#if ENABLED(PIDTEMP)
//#define PID_AUTOTUNE_MENU // Add PID Autotune to the LCD “Temperature” menu to run M303 and apply the result.
//#define PID_DEBUG // Sends debug data to the serial port.
//#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX
//#define SLOW_PWM_HEATERS // PWM with very low frequency (roughly 0.125Hz=8s) and minimum state time of approximately 1s useful for heaters driven by a relay
//#define PID_PARAMS_PER_HOTEND // Uses separate PID parameters for each extruder (useful for mismatched extruders)
// Set/get with gcode: M301 E[extruder number, 0-2]
#define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature
// is more than PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max.
#define K1 0.95 //smoothing factor within the PID
// If you are using a pre-configured hotend then you can use one of the value sets by uncommenting it
// oXis Kossel k800 XL
#define DEFAULT_Kp 22.2
#define DEFAULT_Ki 1.08
#define DEFAULT_Kd 114
// Kossel k800 XL
//#define DEFAULT_Kp 22.25
//#define DEFAULT_Ki 1.45
//#define DEFAULT_Kd 85.30
// MakerGear
//#define DEFAULT_Kp 7.0
//#define DEFAULT_Ki 0.1
//#define DEFAULT_Kd 12
// Mendel Parts V9 on 12V
//#define DEFAULT_Kp 63.0
//#define DEFAULT_Ki 2.25
//#define DEFAULT_Kd 440
#endif // PIDTEMP
//============================= PID > Bed Temperature Control ===============
// Select PID or bang-bang with PIDTEMPBED. If bang-bang, BED_LIMIT_SWITCHING will enable hysteresis
// Uncomment this to enable PID on the bed. It uses the same frequency PWM as the extruder.
// If your PID_dT is the default, and correct for your hardware/configuration, that means 7.689Hz,
// which is fine for driving a square wave into a resistive load and does not significantly impact you FET heating.
// This also works fine on a Fotek SSR-10DA Solid State Relay into a 250W heater.
// If your configuration is significantly different than this and you don’t understand the issues involved, you probably
// shouldn’t use bed PID until someone else verifies your hardware works.
// If this is enabled, find your own PID constants below.
//#define PIDTEMPBED
//#define BED_LIMIT_SWITCHING
// This sets the max power delivered to the bed, and replaces the HEATER_BED_DUTY_CYCLE_DIVIDER option.
// all forms of bed control obey this (PID, bang-bang, bang-bang with hysteresis)
// setting this to anything other than 255 enables a form of PWM to the bed just like HEATER_BED_DUTY_CYCLE_DIVIDER did,
// so you shouldn’t use it unless you are OK with PWM on your bed. (see the comment on enabling PIDTEMPBED)
#define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current
#if ENABLED(PIDTEMPBED)
//#define PID_BED_DEBUG // Sends debug data to the serial port.
//120V 250W silicone heater into 4mm borosilicate (MendelMax 1.5+)
//from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, aggressive factor of .15 (vs .1, 1, 10)
#define DEFAULT_bedKp 10.00
#define DEFAULT_bedKi .023
#define DEFAULT_bedKd 305.4
//from pidautotune
//#define DEFAULT_bedKp 97.1
//#define DEFAULT_bedKi 1.41
//#define DEFAULT_bedKd 1675.16
// FIND YOUR OWN: “M303 E-1 C8 S90” to run autotune on the bed at 90 degreesC for 8 cycles.
#endif // PIDTEMPBED
// @section extruder
// This option prevents extrusion if the temperature is below EXTRUDE_MINTEMP.
// It also enables the M302 command to set the minimum extrusion temperature
// or to allow moving the extruder regardless of the hotend temperature.
// *** IT IS HIGHLY RECOMMENDED TO LEAVE THIS OPTION ENABLED! ***
#define PREVENT_COLD_EXTRUSION
#define EXTRUDE_MINTEMP 170
// This option prevents a single extrusion longer than EXTRUDE_MAXLENGTH.
// Note that for Bowden Extruders a too-small value here may prevent loading.
#define PREVENT_LENGTHY_EXTRUDE
#define EXTRUDE_MAXLENGTH 200
//======================== Thermal Runaway Protection =======================
  • Thermal Protection protects your printer from damage and fire if a
  • thermistor falls out or temperature sensors fail in any way.
  • The issue: If a thermistor falls out or a temperature sensor fails,
  • Marlin can no longer sense the actual temperature. Since a disconnected
  • thermistor reads as a low temperature, the firmware will keep the heater on.
  • If you get “Thermal Runaway” or “Heating failed” errors the
  • details can be tuned in Configuration_adv.h
#define THERMAL_PROTECTION_HOTENDS // Enable thermal protection for all extruders
#define THERMAL_PROTECTION_BED // Enable thermal protection for the heated bed
//============================= Mechanical Settings =========================
// @section machine
// Uncomment one of these options to enable CoreXY, CoreXZ, or CoreYZ kinematics
// either in the usual order or reversed
//#define COREXY
//#define COREXZ
//#define COREYZ
//#define COREYX
//#define COREZX
//#define COREZY
//============================== Delta Settings =============================
// Enable DELTA kinematics and most of the default configuration for Deltas
#define DELTA
#if ENABLED(DELTA)
// Make delta curves from many straight lines (linear interpolation).
// This is a trade-off between visible corners (not enough segments)
// and processor overload (too many expensive sqrt calls).
#define DELTA_SEGMENTS_PER_SECOND 100.0
// Center-to-center distance of the holes in the diagonal push rods.
#define DELTA_DIAGONAL_ROD 202.0 // mm
// Horizontal offset from middle of printer to smooth rod center.
#define DELTA_SMOOTH_ROD_OFFSET 265.0 // mm
// Horizontal offset of the universal joints on the end effector.
#define DELTA_EFFECTOR_OFFSET 33.0 // mm
// Horizontal offset of the universal joints on the carriages.
#define DELTA_CARRIAGE_OFFSET 14.0 // mm
// Horizontal distance bridged by diagonal push rods when effector is centered.
#define DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET - DELTA_EFFECTOR_OFFSET - DELTA_CARRIAGE_OFFSET) //mm // get this value from auto calibrate
// height from z=0.00 to home position
#define DELTA_HEIGHT 155.0 // get this value from auto calibrate - use G33 C-1 at 1st time calibration
// Print surface diameter/2 minus unreachable space (avoid collisions with vertical towers).
#define DELTA_PRINTABLE_RADIUS 100.0
// Delta calibration menu
// See On 3D Delta Printers....
//#define DELTA_CALIBRATION_MENU
// set the radius for the calibration probe points - max 0.8 * DELTA_PRINTABLE_RADIUS if DELTA_AUTO_CALIBRATION enabled
#define DELTA_CALIBRATION_RADIUS (DELTA_PRINTABLE_RADIUS) // mm
// G33 Delta Auto-Calibration (Enable EEPROM_SETTINGS to store results)
//#define DELTA_AUTO_CALIBRATION
#if ENABLED(DELTA_AUTO_CALIBRATION)
#define DELTA_CALIBRATION_DEFAULT_POINTS 3 // set the default number of probe points : n*n (-7 → +7)
#endif
// After homing move down to a height where XY movement is unconstrained
#define DELTA_HOME_TO_SAFE_ZONE
#define DELTA_ENDSTOP_ADJ { 0, 0, 0 } // get these from auto calibrate
// Trim adjustments for individual towers
// tower angle corrections for X and Y tower / rotate XYZ so Z tower angle = 0
// measured in degrees anticlockwise looking from above the printer
#define DELTA_TOWER_ANGLE_TRIM { 0, 0, 0 } // get these from auto calibrate
// delta radius and diaginal rod adjustments measured in mm
//#define DELTA_RADIUS_TRIM_TOWER {0, 0, 0}
//#define DELTA_DIAGONAL_ROD_TRIM_TOWER {0, 0, 0}
#endif
//============================== Endstop Settings ===========================
// @section homing
// Specify here all the endstop connectors that are connected to any endstop or probe.
// Almost all printers will be using one per axis. Probes will use one or more of the
// extra connectors. Leave undefined any used for non-endstop and non-probe purposes.
//#define USE_XMIN_PLUG
//#define USE_YMIN_PLUG
//#define USE_ZMIN_PLUG // a Z probe
#define USE_XMAX_PLUG
#define USE_YMAX_PLUG
#define USE_ZMAX_PLUG
// coarse Endstop Settings
//#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#if DISABLED(ENDSTOPPULLUPS)
// fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined
#define ENDSTOPPULLUP_XMAX
#define ENDSTOPPULLUP_YMAX
#define ENDSTOPPULLUP_ZMAX
//#define ENDSTOPPULLUP_XMIN
//#define ENDSTOPPULLUP_YMIN
//#define ENDSTOPPULLUP_ZMIN
//#define ENDSTOPPULLUP_ZMIN_PROBE
#endif
// Mechanical endstop with COM to ground and NC to Signal uses “false” here (most common setup).
#define X_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Y_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define X_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Y_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Z_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to true to invert the logic of the probe.
// Enable this feature if all enabled endstop pins are interrupt-capable.
// This will remove the need to poll the interrupt pins, saving many CPU cycles.
//#define ENDSTOP_INTERRUPTS_FEATURE
//============================== Movement Settings ============================
// @section motion
// variables to calculate steps
#define XYZ_FULL_STEPS_PER_ROTATION 400
#define XYZ_MICROSTEPS 16
#define XYZ_BELT_PITCH 2
#define XYZ_PULLEY_TEETH 16
// delta speeds must be the same on xyz
#define XYZ_STEPS 55.5
  • Default Settings
  • These settings can be reset by M502
  • Note that if EEPROM is enabled, saved values will override these.
  • With this option each E stepper can have its own factors for the
  • following movement settings. If fewer factors are given than the
  • total number of extruders, the last value applies to the rest.
    //#define DISTINCT_E_FACTORS
  • Default Axis Steps Per Unit (steps/mm)
  • Override with M92
  •                                  X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]]
#define DEFAULT_AXIS_STEPS_PER_UNIT { XYZ_STEPS, XYZ_STEPS, XYZ_STEPS, 158 } // default steps per unit for PowerWasp
  • Default Max Feed Rate (mm/s)
  • Override with M203
#define DEFAULT_MAX_FEEDRATE { 380, 380, 380, 25 }
  • Default Max Acceleration (change/s) change = mm/s
  • (Maximum start speed for accelerated moves)
  • Override with M201
#define DEFAULT_MAX_ACCELERATION { 500, 500, 500, 10000 }
  • Default Acceleration (change/s) change = mm/s
  • Override with M204
  • M204 P Acceleration
  • M204 R Retract Acceleration
  • M204 T Travel Acceleration
    #define DEFAULT_ACCELERATION 380 // X, Y, Z and E acceleration for printing moves
    #define DEFAULT_RETRACT_ACCELERATION 380 // E acceleration for retracts
    #define DEFAULT_TRAVEL_ACCELERATION 380 // X, Y, Z acceleration for travel (non printing) moves
  • Default Jerk (mm/s)
  • Override with M205 X Y Z E
  • “Jerk” specifies the minimum speed change that requires acceleration.
  • When changing speed and direction, if the difference is less than the
  • value set here, it may happen instantaneously.
    #define DEFAULT_XJERK 20.0
    #define DEFAULT_YJERK 20.0
    #define DEFAULT_ZJERK 20.0
    #define DEFAULT_EJERK 15.0
//============================= Z Probe Options =============================
// @section probes
// See http://marlinfw.org/configuration/probes.html
  • Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
  • Enable this option for a probe connected to the Z Min endstop pin.
    //#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
  • Z_MIN_PROBE_ENDSTOP
  • Enable this option for a probe connected to any pin except Z-Min.
  • (By default Marlin assumes the Z-Max endstop pin.)
  • To use a custom Z Probe pin, set Z_MIN_PROBE_PIN below.
    • The simplest option is to use a free endstop connector.
    • Use 5V for powered (usually inductive) sensors.
    • RAMPS 1.3/1.4 boards may use the 5V, GND, and Aux4->D32 pin:
    • For simple switches connect…
  •  - normally-closed switches to GND and D32.
  •  - normally-open switches to 5V and D32.
  • WARNING: Setting the wrong pin may have unexpected and potentially
  • disastrous consequences. Use with caution and do your homework.
//#define Z_MIN_PROBE_ENDSTOP
//#define Z_MIN_PROBE_PIN Z_MAX_PIN
  • Probe Type
  • Allen Key Probes, Servo Probes, Z-Sled Probes, FIX_MOUNTED_PROBE, etc.
  • Activate one of these to use Auto Bed Leveling below.
  • The “Manual Probe” provides a means to do “Auto” Bed Leveling without a probe.
  • Use G29 repeatedly, adjusting the Z height at each point with movement commands
  • or (with LCD_BED_LEVELING) the LCD controller.
    //#define PROBE_MANUALLY
  • A Fix-Mounted Probe either doesn’t deploy or needs manual deployment.
  • (e.g., an inductive probe or a nozzle-based probe-switch.)
    //#define FIX_MOUNTED_PROBE
  • Z Servo Probe, such as an endstop switch on a rotating arm.
    //#define Z_ENDSTOP_SERVO_NR 0 // Defaults to SERVO 0 connector.
    //#define Z_SERVO_ANGLES {70,0} // Z Servo Deploy and Stow angles
  • The BLTouch probe uses a Hall effect sensor and emulates a servo.
    //#define BLTOUCH
    #if ENABLED(BLTOUCH)
    //#define BLTOUCH_DELAY 375 // (ms) Enable and increase if needed
    #endif
  • Enable if probing seems unreliable. Heaters and/or fans - consistent with the
  • options selected below - will be disabled during probing so as to minimize
  • potential EM interference by quieting/silencing the source of the ‘noise’ (the change
  • in current flowing through the wires). This is likely most useful to users of the
  • BLTouch probe, but may also help those with inductive or other probe types.
    //#define PROBING_HEATERS_OFF // Turn heaters off when probing
    //#define PROBING_FANS_OFF // Turn fans off when probing
// A probe that is deployed and stowed with a solenoid pin (SOL1_PIN)
//#define SOLENOID_PROBE
// A sled-mounted probe like those designed by Charles Bell.
//#define Z_PROBE_SLED
//#define SLED_DOCKING_OFFSET 5 // The extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you’d like.
// For Z_PROBE_ALLEN_KEY see the Delta example configurations.
  • Z Probe to nozzle (X,Y) offset, relative to (0, 0).
  • X and Y offsets must be integers.
  • In the following example the X and Y offsets are both positive:
  • #define X_PROBE_OFFSET_FROM_EXTRUDER 10
  • #define Y_PROBE_OFFSET_FROM_EXTRUDER 10
  •  +-- BACK ---+
  • L | (+) P | R ← probe (20,20)
  • E | | I
  • F | (-) N (+) | G ← nozzle (10,10)
  • T | | H
  •  |    (-)    | T
  •  O-- FRONT --+
  • (0,0)
    #define X_PROBE_OFFSET_FROM_EXTRUDER 20 // Z probe to nozzle X offset: -left +right
    #define Y_PROBE_OFFSET_FROM_EXTRUDER 0.0 // Z probe to nozzle Y offset: -front +behind
    #define Z_PROBE_OFFSET_FROM_EXTRUDER -14.7 // Z probe to nozzle Z offset: -below (always!)
// X and Y axis travel speed (mm/m) between probes
#define XY_PROBE_SPEED 8000
// Speed for the first approach when double-probing (with PROBE_DOUBLE_TOUCH)
#define Z_PROBE_SPEED_FAST HOMING_FEEDRATE_Z
// Speed for the “accurate” probe of each point
#define Z_PROBE_SPEED_SLOW (Z_PROBE_SPEED_FAST / 2)
// Use double touch for probing
//#define PROBE_DOUBLE_TOUCH
  • Allen key retractable z-probe as seen on many Kossel delta printers - Kossel - RepRap
  • Deploys by touching z-axis belt. Retracts by pushing the probe down. Uses Z_MIN_PIN.
    //#define Z_PROBE_ALLEN_KEY
#if ENABLED(Z_PROBE_ALLEN_KEY)
// 2 or 3 sets of coordinates for deploying and retracting the spring loaded touch probe on G29,
// if servo actuated touch probe is not defined. Uncomment as appropriate for your printer/probe.
//#define Z_PROBE_ALLEN_KEY_DEPLOY_1_X 30.0
//#define Z_PROBE_ALLEN_KEY_DEPLOY_1_Y DELTA_PRINTABLE_RADIUS
//#define Z_PROBE_ALLEN_KEY_DEPLOY_1_Z 100.0
//#define Z_PROBE_ALLEN_KEY_DEPLOY_1_FEEDRATE XY_PROBE_SPEED
//#define Z_PROBE_ALLEN_KEY_DEPLOY_2_X 0.0
//#define Z_PROBE_ALLEN_KEY_DEPLOY_2_Y DELTA_PRINTABLE_RADIUS
//#define Z_PROBE_ALLEN_KEY_DEPLOY_2_Z 100.0
//#define Z_PROBE_ALLEN_KEY_DEPLOY_2_FEEDRATE (XY_PROBE_SPEED)/10
//#define Z_PROBE_ALLEN_KEY_DEPLOY_3_X Z_PROBE_ALLEN_KEY_DEPLOY_2_X * 0.75
//#define Z_PROBE_ALLEN_KEY_DEPLOY_3_Y Z_PROBE_ALLEN_KEY_DEPLOY_2_Y * 0.75
//#define Z_PROBE_ALLEN_KEY_DEPLOY_3_Z Z_PROBE_ALLEN_KEY_DEPLOY_2_Z
//#define Z_PROBE_ALLEN_KEY_DEPLOY_3_FEEDRATE XY_PROBE_SPEED
//#define Z_PROBE_ALLEN_KEY_STOW_1_X -64.0 // Move the probe into position
//#define Z_PROBE_ALLEN_KEY_STOW_1_Y 56.0
//#define Z_PROBE_ALLEN_KEY_STOW_1_Z 23.0
//#define Z_PROBE_ALLEN_KEY_STOW_1_FEEDRATE XY_PROBE_SPEED
//#define Z_PROBE_ALLEN_KEY_STOW_2_X -64.0 // Push it down
//#define Z_PROBE_ALLEN_KEY_STOW_2_Y 56.0
//#define Z_PROBE_ALLEN_KEY_STOW_2_Z 3.0
//#define Z_PROBE_ALLEN_KEY_STOW_2_FEEDRATE (XY_PROBE_SPEED)/10
//#define Z_PROBE_ALLEN_KEY_STOW_3_X -64.0 // Move it up to clear
//#define Z_PROBE_ALLEN_KEY_STOW_3_Y 56.0
//#define Z_PROBE_ALLEN_KEY_STOW_3_Z 50.0
//#define Z_PROBE_ALLEN_KEY_STOW_3_FEEDRATE XY_PROBE_SPEED
//#define Z_PROBE_ALLEN_KEY_STOW_4_X 0.0
//#define Z_PROBE_ALLEN_KEY_STOW_4_Y 0.0
//#define Z_PROBE_ALLEN_KEY_STOW_4_Z Z_PROBE_ALLEN_KEY_STOW_3_Z
//#define Z_PROBE_ALLEN_KEY_STOW_4_FEEDRATE XY_PROBE_SPEED
#endif // Z_PROBE_ALLEN_KEY
  • *** PLEASE READ ALL INSTRUCTIONS BELOW FOR SAFETY! ***
    • RAMPS 1.3/1.4 boards may be able to use the 5V, GND, and Aux4->D32 pin.
    • Use 5V for powered (usu. inductive) sensors.
    • Otherwise connect:
  • Normally-closed switches are advised and are the default.
  • PIN OPTIONS\SETUP FOR Z PROBES
  • WARNING:
  • Setting the wrong pin may have unexpected and potentially disastrous consequences.
  • Use with caution and do your homework.
  • All Z PROBE pin options are configured by defining (or not defining)
  • the following five items:
  •   Z_MIN_PROBE_ENDSTOP – defined below
  •   Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN – defined below
  •   Z_MIN_PIN - defined in the pins_YOUR_BOARD.h file
  •   Z_MIN_PROBE_PIN - defined in the pins_YOUR_BOARD.h file
  • If you’re using a probe then you need to tell Marlin which pin to use as
  • the Z MIN ENDSTOP. Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN determines if the
  • Z_MIN_PIN or if the Z_MIN_PROBE_PIN is used.
  • The pin selected for the probe is ONLY checked during probing operations.
  • If you want to use the Z_MIN_PIN as an endstop AND you want to have a Z PROBE
  • then you’ll need to use the Z_MIN_PROBE_PIN option.
  • Z_MIN_PROBE_ENDSTOP also needs to be enabled if you want to use Z_MIN_PROBE_PIN.
  • The settings needed to use the Z_MIN_PROBE_PIN are:
  •   1. select the type of probe you're using
  •   2. define Z_MIN_PROBE_PIN in your pins_YOUR_BOARD.h file
  •   3. disable Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
  •   4. enable Z_MIN_PROBE_ENDSTOP
  • NOTE – if Z_MIN_PIN is defined then it’ll be checked during all moves in the
  •      negative Z direction.
  • The settings needed to use the Z_MIN_PIN are:
  •   2. enable Z_MIN _PIN in your pins_YOUR_BOARD.h file
  •   3. enable Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
  •   4. disable Z_MIN_PROBE_ENDSTOP
  • NOTES – if Z_MIN_PROBE_PIN is defined in the pins_YOUR_BOARD.h file then it’ll be
  •      ignored by Marlin
  • Z probes require clearance when deploying, stowing, and moving between
  • probe points to avoid hitting the bed and other hardware.
  • Servo-mounted probes require extra space for the arm to rotate.
  • Inductive probes need space to keep from triggering early.
  • Use these settings to specify the distance (mm) to raise the probe (or
  • lower the bed). The values set here apply over and above any (negative)
  • probe Z Offset set with Z_PROBE_OFFSET_FROM_EXTRUDER, M851, or the LCD.
  • Only integer values >= 1 are valid here.
  • Example: M851 Z-5 with a CLEARANCE of 4 => 9mm from bed to nozzle.
  • But: `M851 Z+1` with a CLEARANCE of 2  =>  2mm from bed to nozzle.
#define Z_CLEARANCE_DEPLOY_PROBE 20 // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_BETWEEN_PROBES 10 // Z Clearance between probe points
// For M851 give a range for adjusting the Z probe offset
#define Z_PROBE_OFFSET_RANGE_MIN -20
#define Z_PROBE_OFFSET_RANGE_MAX 20
// Enable the M48 repeatability test to test probe accuracy
//#define Z_MIN_PROBE_REPEATABILITY_TEST
// For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1
// :{ 0:‘Low’, 1:‘High’ }
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis stepper immediately when it’s not being used.
// WARNING: When motors turn off there is a chance of losing position accuracy!
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
// Warn on display about possibly reduced accuracy
//#define DISABLE_REDUCED_ACCURACY_WARNING
#define DISABLE_E false // For all extruders
#define DISABLE_INACTIVE_EXTRUDER true // Keep only the active extruder enabled.
// @section machine
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
#define INVERT_X_DIR true // DELTA does not invert
#define INVERT_Y_DIR true
#define INVERT_Z_DIR true
// Enable this option for Toshiba stepper drivers
//#define CONFIG_STEPPERS_TOSHIBA
// For direct drive extruder v9 set to true, for geared extruder set to false.
#define INVERT_E0_DIR true
#define INVERT_E1_DIR false
#define INVERT_E2_DIR false
#define INVERT_E3_DIR false
#define INVERT_E4_DIR false
// @section homing
//#define Z_HOMING_HEIGHT 4 // (in mm) Minimal z height before homing (G28) for Z clearance above the bed, clamps, …
// Be sure you have this distance over your Z_MAX_POS in case.
// Direction of endstops when homing; 1=MAX, -1=MIN
// :[-1,1]
#define X_HOME_DIR 1 // deltas always home to max
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
// @section machine
// Travel limits after homing (units are in mm)
#define X_MIN_POS -(DELTA_PRINTABLE_RADIUS)
#define Y_MIN_POS -(DELTA_PRINTABLE_RADIUS)
#define Z_MIN_POS 0
#define X_MAX_POS DELTA_PRINTABLE_RADIUS
#define Y_MAX_POS DELTA_PRINTABLE_RADIUS
#define Z_MAX_POS MANUAL_Z_HOME_POS
// If enabled, axes won’t move below MIN_POS in response to movement commands.
//#define MIN_SOFTWARE_ENDSTOPS
// If enabled, axes won’t move above MAX_POS in response to movement commands.
#define MAX_SOFTWARE_ENDSTOPS
  • Filament Runout Sensor
  • A mechanical or opto endstop is used to check for the presence of filament.
  • RAMPS-based boards use SERVO3_PIN.
  • For other boards you may need to define FIL_RUNOUT_PIN.
  • By default the firmware assumes HIGH = has filament, LOW = ran out
    //#define FILAMENT_RUNOUT_SENSOR
    #if ENABLED(FILAMENT_RUNOUT_SENSOR)
    #define FIL_RUNOUT_INVERTING false // set to true to invert the logic of the sensor.
    #define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined.
    #define FILAMENT_RUNOUT_SCRIPT “M600”
    #endif
//=============================== Bed Leveling ==============================
// @section bedlevel
  • Choose one of the options below to enable G29 Bed Leveling. The parameters
  • and behavior of G29 will change depending on your selection.
  • If using a Probe for Z Homing, enable Z_SAFE_HOMING also!
    • AUTO_BED_LEVELING_3POINT
  • Probe 3 arbitrary points on the bed (that aren’t collinear)
  • You specify the XY coordinates of all 3 points.
  • The result is a single tilted plane. Best for a flat bed.
    • AUTO_BED_LEVELING_LINEAR
  • Probe several points in a grid.
  • You specify the rectangle and the density of sample points.
    • AUTO_BED_LEVELING_BILINEAR
  • The result is a mesh, best for large or uneven beds.
    • AUTO_BED_LEVELING_UBL (Unified Bed Leveling)
  • A comprehensive bed leveling system combining the features and benefits
  • of other systems. UBL also includes integrated Mesh Generation, Mesh
  • Validation and Mesh Editing systems. Currently, UBL is only checked out
  • for Cartesian Printers. That said, it was primarily designed to correct
  • poor quality Delta Printers. If you feel adventurous and have a Delta,
  • please post an issue if something doesn’t work correctly. Initially,
  • you will need to set a reduced bed size so you have a rectangular area
  • to test on.
    • MESH_BED_LEVELING
  • Probe a grid manually
  • The result is a mesh, suitable for large or uneven beds. (See BILINEAR.)
  • For machines without a probe, Mesh Bed Leveling provides a method to perform
  • leveling in steps so you can manually adjust the Z height at each grid-point.
  • With an LCD controller the process is guided step-by-step.
    //#define AUTO_BED_LEVELING_3POINT
    //#define AUTO_BED_LEVELING_LINEAR
    //#define AUTO_BED_LEVELING_BILINEAR
    //#define AUTO_BED_LEVELING_UBL
    //#define MESH_BED_LEVELING
  • Enable detailed logging of G28, G29, M48, etc.
  • Turn on with the command ‘M111 S32’.
  • NOTE: Requires a lot of PROGMEM!
    //#define DEBUG_LEVELING_FEATURE
#if ENABLED(MESH_BED_LEVELING) || ENABLED(AUTO_BED_LEVELING_BILINEAR) || ENABLED(AUTO_BED_LEVELING_UBL)
// Gradually reduce leveling correction until a set height is reached,
// at which point movement will be level to the machine’s XY plane.
// The height can be set with M420 Z
//#define ENABLE_LEVELING_FADE_HEIGHT
#endif
#if ENABLED(AUTO_BED_LEVELING_LINEAR) || ENABLED(AUTO_BED_LEVELING_BILINEAR)
// Set the number of grid points per dimension.
// Works best with 5 or more points in each dimension.
#define GRID_MAX_POINTS_X 5
#define GRID_MAX_POINTS_Y GRID_MAX_POINTS_X
// Set the boundaries for probing (where the probe can reach).
#define DELTA_PROBEABLE_RADIUS (DELTA_PRINTABLE_RADIUS - 10)
#define LEFT_PROBE_BED_POSITION -(DELTA_PROBEABLE_RADIUS)
#define RIGHT_PROBE_BED_POSITION DELTA_PROBEABLE_RADIUS
#define FRONT_PROBE_BED_POSITION - (DELTA_PROBEABLE_RADIUS - 20)
#define BACK_PROBE_BED_POSITION DELTA_PROBEABLE_RADIUS - 40
// The Z probe minimum outer margin (to validate G29 parameters).
#define MIN_PROBE_EDGE 10
// Probe along the Y axis, advancing X after each column
//#define PROBE_Y_FIRST
#if ENABLED(AUTO_BED_LEVELING_BILINEAR)
// Experimental Subdivision of the grid by Catmull-Rom method.
// Synthesizes intermediate points to produce a more detailed mesh.
//#define ABL_BILINEAR_SUBDIVISION
#if ENABLED(ABL_BILINEAR_SUBDIVISION)
// Number of subdivisions between probe points
#define BILINEAR_SUBDIVISIONS 3
#endif
#endif
#elif ENABLED(AUTO_BED_LEVELING_3POINT)
// 3 arbitrary points to probe.
// A simple cross-product is used to estimate the plane of the bed.
#define ABL_PROBE_PT_1_X 15
#define ABL_PROBE_PT_1_Y 180
#define ABL_PROBE_PT_2_X 15
#define ABL_PROBE_PT_2_Y 20
#define ABL_PROBE_PT_3_X 170
#define ABL_PROBE_PT_3_Y 20
#elif ENABLED(AUTO_BED_LEVELING_UBL)
//========================= Unified Bed Leveling ============================
#define UBL_MESH_INSET 1 // Mesh inset margin on print area
#define GRID_MAX_POINTS_X 10 // Don’t use more than 15 points per axis, implementation limited.
#define UBL_PROBE_PT_1_X 39 // These set the probe locations for when UBL does a 3-Point leveling
#define UBL_PROBE_PT_1_Y 180 // of the mesh.
#define UBL_PROBE_PT_2_X 39
#define UBL_PROBE_PT_2_Y 20
#define UBL_PROBE_PT_3_X 180
#define UBL_PROBE_PT_3_Y 20
//#define UBL_G26_MESH_EDITING // Enable G26 mesh editing
#elif ENABLED(MESH_BED_LEVELING)
//=================================== Mesh ==================================
#define MESH_INSET 10 // Mesh inset margin on print area
#define GRID_MAX_POINTS_X 3 // Don’t use more than 7 points per axis, implementation limited.
//#define MESH_G28_REST_ORIGIN // After homing all axes (‘G28’ or ‘G28 XYZ’) rest Z at Z_MIN_POS
#endif // BED_LEVELING
  • Use the LCD controller for bed leveling
  • Requires MESH_BED_LEVELING or PROBE_MANUALLY
    //#define LCD_BED_LEVELING
#if ENABLED(LCD_BED_LEVELING)
#define MBL_Z_STEP 0.025 // Step size while manually probing Z axis.
#define LCD_PROBE_Z_RANGE 4 // Z Range centered on Z_MIN_POS for LCD Z adjustment
#endif
  • Commands to execute at the end of G29 probing.
  • Useful to retract or move the Z probe out of the way.
    //#define Z_PROBE_END_SCRIPT “G1 Z10 F12000\nG1 X15 Y330\nG1 Z0.5\nG1 Z10”
// @section homing
// The center of the bed is at (X=0, Y=0)
#define BED_CENTER_AT_0_0
// Manually set the home position. Leave these undefined for automatic settings.
// For DELTA this is the top-center of the Cartesian print volume.
//#define MANUAL_X_HOME_POS 0
//#define MANUAL_Y_HOME_POS 0
#define MANUAL_Z_HOME_POS DELTA_HEIGHT // Distance between the nozzle to printbed after homing
// Use “Z Safe Homing” to avoid homing with a Z probe outside the bed area.
// With this feature enabled:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled.
// - If stepper drivers time out, it will need X and Y homing again before Z homing.
// - Move the Z probe (or nozzle) to a defined XY point before Z Homing when homing all axes (G28).
// - Prevent Z homing when the Z probe is outside bed area.
//#define Z_SAFE_HOMING
#if ENABLED(Z_SAFE_HOMING)
#define Z_SAFE_HOMING_X_POINT ((X_MIN_POS + X_MAX_POS) / 2) // X point for Z homing when homing all axis (G28).
#define Z_SAFE_HOMING_Y_POINT ((Y_MIN_POS + Y_MAX_POS) / 2) // Y point for Z homing when homing all axis (G28).
#endif
// Delta only homes to Z
#define HOMING_FEEDRATE_Z (60*60)
//============================= Additional Features ===========================
// @section extras
// EEPROM
// The microcontroller can store settings in the EEPROM, e.g. max velocity…
// M500 - stores parameters in EEPROM
// M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
// M502 - reverts to the default “factory settings”. You still need to store them in EEPROM afterwards if you want to.
//define this to enable EEPROM support
#define EEPROM_SETTINGS
#if ENABLED(EEPROM_SETTINGS)
// To disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out:
#define EEPROM_CHITCHAT // Please keep turned on if you can.
#endif
// Host Keepalive
// When enabled Marlin will send a busy status message to the host
// every couple of seconds when it can’t accept commands.
#define HOST_KEEPALIVE_FEATURE // Disable this if your host doesn’t like keepalive messages
#define DEFAULT_KEEPALIVE_INTERVAL 2 // Number of seconds between “busy” messages. Set with M113.
// M100 Free Memory Watcher
//#define M100_FREE_MEMORY_WATCHER // uncomment to add the M100 Free Memory Watcher for debug purpose
// G20/G21 Inch mode support
//#define INCH_MODE_SUPPORT
// M149 Set temperature units support
//#define TEMPERATURE_UNITS_SUPPORT
// Preheat Constants
#define PREHEAT_1_TEMP_HOTEND 180
#define PREHEAT_1_TEMP_BED 70
#define PREHEAT_1_FAN_SPEED 255 // Value from 0 to 255
#define PREHEAT_2_TEMP_HOTEND 240
#define PREHEAT_2_TEMP_BED 100
#define PREHEAT_2_FAN_SPEED 255 // Value from 0 to 255
  • Nozzle Park – EXPERIMENTAL
  • Park the nozzle at the given XYZ position on idle or G27.
  • The “P” parameter controls the action applied to the Z axis:
  • P0 (Default) If Z is below park Z raise the nozzle.
  • P1 Raise the nozzle always to Z-park height.
  • P2 Raise the nozzle by Z-park amount, limited to Z_MAX_POS.
    //#define NOZZLE_PARK_FEATURE
#if ENABLED(NOZZLE_PARK_FEATURE)
// Specify a park position as { X, Y, Z }
#define NOZZLE_PARK_POINT { (X_MIN_POS + 10), (Y_MAX_POS - 10), 20 }
#endif
  • Clean Nozzle Feature – EXPERIMENTAL
  • Adds the G12 command to perform a nozzle cleaning process.
  • Parameters:
  • P Pattern
  • S Strokes / Repetitions
  • T Triangles (P1 only)
  • Patterns:
  • P0 Straight line (default). This process requires a sponge type material
  •   at a fixed bed location. "S" specifies strokes (i.e. back-forth motions)
  •   between the start / end points.
  • P1 Zig-zag pattern between (X0, Y0) and (X1, Y1), “T” specifies the
  •   number of zig-zag triangles to do. "S" defines the number of strokes.
  •   Zig-zags are done in whichever is the narrower dimension.
  •   For example, "G12 P1 S1 T3" will execute:
  •     |  (X0, Y1) |     /\        /\        /\     | (X1, Y1)
  •   A |           |   /    \    /    \    /    \   |
  •     |  (X0, Y0) | /        \/        \/        \ | (X1, Y0)
  •                   |________|_________|_________|
  •                       T1        T2        T3
  • P2 Circular pattern with middle at NOZZLE_CLEAN_CIRCLE_MIDDLE.
  •   "R" specifies the radius. "S" specifies the stroke count.
  •   Before starting, the nozzle moves to NOZZLE_CLEAN_START_POINT.
  • Caveats: The ending Z should be the same as starting Z.
  • Attention: EXPERIMENTAL. G-code arguments may change.
//#define NOZZLE_CLEAN_FEATURE
#if ENABLED(NOZZLE_CLEAN_FEATURE)
// Default number of pattern repetitions
#define NOZZLE_CLEAN_STROKES 12
// Default number of triangles
#define NOZZLE_CLEAN_TRIANGLES 3
// Specify positions as { X, Y, Z }
#define NOZZLE_CLEAN_START_POINT { 30, 30, (Z_MIN_POS + 1)}
#define NOZZLE_CLEAN_END_POINT {100, 60, (Z_MIN_POS + 1)}
// Circular pattern radius
#define NOZZLE_CLEAN_CIRCLE_RADIUS 6.5
// Circular pattern circle fragments number
#define NOZZLE_CLEAN_CIRCLE_FN 10
// Middle point of circle
#define NOZZLE_CLEAN_CIRCLE_MIDDLE NOZZLE_CLEAN_START_POINT
// Moves the nozzle to the initial position
#define NOZZLE_CLEAN_GOBACK
#endif
  • Print Job Timer
  • Automatically start and stop the print job timer on M104/M109/M190.
  • M104 (hotend, no wait) - high temp = none, low temp = stop timer
  • M109 (hotend, wait) - high temp = start timer, low temp = stop timer
  • M190 (bed, wait) - high temp = start timer, low temp = none
  • The timer can also be controlled with the following commands:
  • M75 - Start the print job timer
  • M76 - Pause the print job timer
  • M77 - Stop the print job timer
    #define PRINTJOB_TIMER_AUTOSTART
  • Print Counter
  • Track statistical data such as:
    • Total print jobs
    • Total successful print jobs
    • Total failed print jobs
    • Total time printing
  • View the current statistics with M78.
    //#define PRINTCOUNTER
//============================= LCD and SD support ============================
// @section lcd
  • LCD LANGUAGE
  • Select the language to display on the LCD. These languages are available:
  • en, an, bg, ca, cn, cz, de, el, el-gr, es, eu, fi, fr, gl, hr, it,
  • kana, kana_utf8, nl, pl, pt, pt_utf8, pt-br, pt-br_utf8, ru, tr, uk, test
  • :{ ‘en’:‘English’, ‘an’:‘Aragonese’, ‘bg’:‘Bulgarian’, ‘ca’:‘Catalan’, ‘cn’:‘Chinese’, ‘cz’:‘Czech’, ‘de’:‘German’, ‘el’:‘Greek’, ‘el-gr’:‘Greek (Greece)’, ‘es’:‘Spanish’, ‘eu’:‘Basque-Euskera’, ‘fi’:‘Finnish’, ‘fr’:‘French’, ‘gl’:‘Galician’, ‘hr’:‘Croatian’, ‘it’:‘Italian’, ‘kana’:‘Japanese’, ‘kana_utf8’:‘Japanese (UTF8)’, ‘nl’:‘Dutch’, ‘pl’:‘Polish’, ‘pt’:‘Portuguese’, ‘pt-br’:‘Portuguese (Brazilian)’, ‘pt-br_utf8’:‘Portuguese (Brazilian UTF8)’, ‘pt_utf8’:‘Portuguese (UTF8)’, ‘ru’:‘Russian’, ‘tr’:‘Turkish’, ‘uk’:‘Ukrainian’, ‘test’:‘TEST’ }
    #define LCD_LANGUAGE en
  • LCD TYPE
  • Enable ULTRA_LCD for a 16x2, 16x4, 20x2, or 20x4 character-based LCD.
  • Enable DOGLCD for a 128x64 (ST7565R) Full Graphical Display.
  • (These options will be enabled automatically for most displays.)
  • IMPORTANT: The U8glib library is required for Full Graphic Display!
  •        https://github.com/olikraus/U8glib_Arduino
//#define ULTRA_LCD // Character based
//#define DOGLCD // Full graphics display
  • SD CARD
  • SD Card support is disabled by default. If your controller has an SD slot,
  • you must uncomment the following option or it won’t work.
//#define SDSUPPORT
  • SD CARD: SPI SPEED
  • Enable one of the following items for a slower SPI transfer speed.
  • This may be required to resolve “volume init” errors.
    //#define SPI_SPEED SPI_HALF_SPEED
    //#define SPI_SPEED SPI_QUARTER_SPEED
    //#define SPI_SPEED SPI_EIGHTH_SPEED
  • SD CARD: ENABLE CRC
  • Use CRC checks and retries on the SD communication.
    //#define SD_CHECK_AND_RETRY
// ENCODER SETTINGS
// This option overrides the default number of encoder pulses needed to
// produce one step. Should be increased for high-resolution encoders.
//#define ENCODER_PULSES_PER_STEP 1
// Use this option to override the number of step signals required to
// move between next/prev menu items.
//#define ENCODER_STEPS_PER_MENU_ITEM 5
  • Encoder Direction Options
  • Test your encoder’s behavior first with both options disabled.
  • Reversed Value Edit and Menu Nav? Enable REVERSE_ENCODER_DIRECTION.
  • Reversed Menu Navigation only? Enable REVERSE_MENU_DIRECTION.
  • Reversed Value Editing only? Enable BOTH options.
// This option reverses the encoder direction everywhere.
// Set this option if CLOCKWISE causes values to DECREASE
//#define REVERSE_ENCODER_DIRECTION
// This option reverses the encoder direction for navigating LCD menus.
// If CLOCKWISE normally moves DOWN this makes it go UP.
// If CLOCKWISE normally moves UP this makes it go DOWN.
//#define REVERSE_MENU_DIRECTION
// Individual Axis Homing
// Add individual axis homing items (Home X, Home Y, and Home Z) to the LCD menu.
//#define INDIVIDUAL_AXIS_HOMING_MENU
// SPEAKER/BUZZER
// If you have a speaker that can produce tones, enable it here.
// By default Marlin assumes you have a buzzer with a fixed frequency.
//#define SPEAKER
// The duration and frequency for the UI feedback sound.
// Set these to 0 to disable audio feedback in the LCD menus.
// Note: Test audio output with the G-Code:
// M300 S P
//#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100
//#define LCD_FEEDBACK_FREQUENCY_HZ 1000
// CONTROLLER TYPE: Standard
// Marlin supports a wide variety of controllers.
// Enable one of the following options to specify your controller.
// ULTIMAKER Controller.
//#define ULTIMAKERCONTROLLER
// ULTIPANEL as seen on Thingiverse.
//#define ULTIPANEL
// Cartesio UI
// http://mauk.cc/webshop/cartesio-shop/electronics/user-interface
//#define CARTESIO_UI
// PanelOne from T3P3 (via RAMPS 1.4 AUX2/AUX3)
// PanelOne - RepRap
//#define PANEL_ONE
// MaKr3d Makr-Panel with graphic controller and SD support.
// MaKr3d MaKrPanel - RepRap
//#define MAKRPANEL
// ReprapWorld Graphical LCD
// Welcome to reprapworld.com | 3D printing experts | ReprapWorld USA
//#define REPRAPWORLD_GRAPHICAL_LCD
// Activate one of these if you have a Panucatt Devices
// Viki 2.0 or mini Viki with Graphic LCD
// http://panucatt.com
//#define VIKI2
//#define miniVIKI
// Adafruit ST7565 Full Graphic Controller.
// GitHub - eboston/Adafruit-ST7565-Full-Graphic-Controller: 3D Printer Controller based around the Adafruit ST7565 display
//#define ELB_FULL_GRAPHIC_CONTROLLER
// RepRapDiscount Smart Controller.
// RepRapDiscount Smart Controller - RepRap
// Note: Usually sold with a white PCB.
//#define REPRAP_DISCOUNT_SMART_CONTROLLER
// GADGETS3D G3D LCD/SD Controller
// RAMPS 1.3/1.4 GADGETS3D Shield with Panel - RepRap
// Note: Usually sold with a blue PCB.
//#define G3D_PANEL
// RepRapDiscount FULL GRAPHIC Smart Controller
// RepRapDiscount Full Graphic Smart Controller - RepRap
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// MakerLab Mini Panel with graphic
// controller and SD support - Mini panel - RepRap
//#define MINIPANEL
// RepRapWorld REPRAPWORLD_KEYPAD v1.1
// REPRAPWORLD_KEYPAD_MOVE_STEP sets how much should the robot move when a key
// is pressed, a value of 10.0 means 10mm per click.
//#define REPRAPWORLD_KEYPAD
//#define REPRAPWORLD_KEYPAD_MOVE_STEP 1.0
// RigidBot Panel V1.0
// http://www.inventapart.com/
//#define RIGIDBOT_PANEL
// BQ LCD Smart Controller shipped by
// default with the BQ Hephestos 2 and Witbox 2.
//#define BQ_LCD_SMART_CONTROLLER
// CONTROLLER TYPE: I2C
// Note: These controllers require the installation of Arduino’s LiquidCrystal_I2C
// library. For more info: GitHub - kiyoshigawa/LiquidCrystal_I2C: LiquidCrystal_I2C Library for Arduino designed to work with the Elefu Control Panel I2C LCD Backpack.
// Elefu RA Board Control Panel
// http://www.elefu.com/index.php?route=product/product&product_id=53
//#define RA_CONTROL_PANEL
// Sainsmart YW Robot (LCM1602) LCD Display
//#define LCD_I2C_SAINSMART_YWROBOT
// Generic LCM1602 LCD adapter
//#define LCM1602
// PANELOLU2 LCD with status LEDs,
// separate encoder and click inputs.
// Note: This controller requires Arduino’s LiquidTWI2 library v1.2.3 or later.
// For more info: GitHub - lincomatic/LiquidTWI2: A lean, high speed I2C LCD Library for Arduino, which supports MCP23008 and MCP23017
// Note: The PANELOLU2 encoder click input can either be directly connected to
// a pin (if BTN_ENC defined to != -1) or read through I2C (when BTN_ENC == -1).
//#define LCD_I2C_PANELOLU2
// Panucatt VIKI LCD with status LEDs,
// integrated click & L/R/U/D buttons, separate encoder inputs.
//#define LCD_I2C_VIKI
// SSD1306 OLED full graphics generic display
//#define U8GLIB_SSD1306
// SAV OLEd LCD module support using either SSD1306 or SH1106 based LCD modules
//#define SAV_3DGLCD
#if ENABLED(SAV_3DGLCD)
#define U8GLIB_SH1106
#endif
// CONTROLLER TYPE: Shift register panels
// 2 wire Non-latching LCD SR from https://goo.gl/aJJ4sH
// LCD configuration: SAV 3D LCD - RepRap
//#define SAV_3DLCD
// TinyBoy2 128x64 OLED / Encoder Panel
//#define OLED_PANEL_TINYBOY2
//=============================== Extra Features ==============================
// @section extras
// Increase the FAN PWM frequency. Removes the PWM noise but increases heating in the FET/Arduino
//#define FAST_PWM_FAN
// Use software PWM to drive the fan, as for the heaters. This uses a very low frequency
// which is not as annoying as with the hardware PWM. On the other hand, if this frequency
// is too low, you should also increment SOFT_PWM_SCALE.
//#define FAN_SOFT_PWM
// Incrementing this by 1 will double the software PWM frequency,
// affecting heaters, and the fan if FAN_SOFT_PWM is enabled.
// However, control resolution will be halved for each increment;
// at zero value, there are 128 effective control positions.
#define SOFT_PWM_SCALE 0
// If SOFT_PWM_SCALE is set to a value higher than 0, dithering can
// be used to mitigate the associated resolution loss. If enabled,
// some of the PWM cycles are stretched so on average the desired
// duty cycle is attained.
//#define SOFT_PWM_DITHER
// Temperature status LEDs that display the hotend and bed temperature.
// If all hotends, bed temperature, and target temperature are under 54C
// then the BLUE led is on. Otherwise the RED led is on. (1C hysteresis)
//#define TEMP_STAT_LEDS
// M240 Triggers a camera by emulating a Canon RC-1 Remote
// Data from: www.doc-diy.net :: Canon RC-1 remote control reverse engineered
//#define PHOTOGRAPH_PIN 23
// SkeinForge sends the wrong arc g-codes when using Arc Point as fillet procedure
//#define SF_ARC_FIX
// Support for the BariCUDA Paste Extruder.
//#define BARICUDA
//define BlinkM/CyzRgb Support
//#define BLINKM
  • RGB LED / LED Strip Control
  • Enable support for an RGB LED connected to 5V digital pins, or
  • an RGB Strip connected to MOSFETs controlled by digital pins.
  • Adds the M150 command to set the LED (or LED strip) color.
  • If pins are PWM capable (e.g., 4, 5, 6, 11) then a range of
  • luminance values can be set from 0 to 255.
  • *** CAUTION ***
  • LED Strips require a MOFSET Chip between PWM lines and LEDs,
  • as the Arduino cannot handle the current the LEDs will require.
  • Failure to follow this precaution can destroy your Arduino!
  • *** CAUTION ***
//#define RGB_LED
//#define RGBW_LED
#if ENABLED(RGB_LED) || ENABLED(RGBW_LED)
#define RGB_LED_R_PIN 34
#define RGB_LED_G_PIN 43
#define RGB_LED_B_PIN 35
#define RGB_LED_W_PIN -1
#endif
  • Printer Event LEDs
  • During printing, the LEDs will reflect the printer status:
    • Gradually change from blue to violet as the heated bed gets to target temp
    • Gradually change from violet to red as the hotend gets to temperature
    • Change to white to illuminate work surface
    • Change to green once print has finished
    • Turn off after the print has finished and the user has pushed a button
      #if ENABLED(BLINKM) || ENABLED(RGB_LED) || ENABLED(RGBW_LED)
      #define PRINTER_EVENT_LEDS
      #endif
  • R/C SERVO support
  • Sponsored by TrinityLabs, Reworked by codexmas
// Number of servos
// If you select a configuration below, this will receive a default value and does not need to be set manually
// set it manually if you have more servos than extruders and wish to manually control some
// leaving it undefined or defining as 0 will disable the servo subsystem
// If unsure, leave commented / disabled
//#define NUM_SERVOS 3 // Servo index starts with 0 for M280 command
// Delay (in milliseconds) before the next move will start, to give the servo time to reach its target angle.
// 300ms is a good value but you can try less delay.
// If the servo can’t reach the requested position, increase it.
#define SERVO_DELAY 300
// Servo deactivation
// With this option servos are powered only during movement, then turned off to prevent jitter.
//#define DEACTIVATE_SERVOS_AFTER_MOVE
  • Filament Width Sensor
  • Measures the filament width in real-time and adjusts
  • flow rate to compensate for any irregularities.
  • Also allows the measured filament diameter to set the
  • extrusion rate, so the slicer only has to specify the
  • volume.
  • Only a single extruder is supported at this time.
  • 34 RAMPS_14 : Analog input 5 on the AUX2 connector
  • 81 PRINTRBOARD : Analog input 2 on the Exp1 connector (version B,C,D,E)
  • 301 RAMBO : Analog input 3
  • Note: May require analog pins to be defined for other boards.
    //#define FILAMENT_WIDTH_SENSOR
#define DEFAULT_NOMINAL_FILAMENT_DIA 3.00 // (mm) Diameter of the filament generally used (3.0 or 1.75mm), also used in the slicer. Used to validate sensor reading.
#if ENABLED(FILAMENT_WIDTH_SENSOR)
#define FILAMENT_SENSOR_EXTRUDER_NUM 0 // Index of the extruder that has the filament sensor (0,1,2,3)
#define MEASUREMENT_DELAY_CM 14 // (cm) The distance from the filament sensor to the melting chamber
#define MEASURED_UPPER_LIMIT 3.30 // (mm) Upper limit used to validate sensor reading
#define MEASURED_LOWER_LIMIT 1.90 // (mm) Lower limit used to validate sensor reading
#define MAX_MEASUREMENT_DELAY 20 // (bytes) Buffer size for stored measurements (1 byte per cm). Must be larger than MEASUREMENT_DELAY_CM.
#define DEFAULT_MEASURED_FILAMENT_DIA DEFAULT_NOMINAL_FILAMENT_DIA // Set measured to nominal initially
// Display filament width on the LCD status line. Status messages will expire after 5 seconds.
//#define FILAMENT_LCD_DISPLAY
#endif
#endif // CONFIGURATION_H
