jakel7
I flashed me Da Vinci 1.0A to repetier a few weeks ago, and after minimal adjustments I was getting excellent prints in ABS.
I upped my infill to 60% to print the MPCNC. At that point the print failed and the nozzle seemed to be clogged. While I was trying to clean the nozzle (using fine guitar wire, and then a toothpick) the extruder fan stopped and the LCD display went off. There are no obvious disconnects on the printer or fraying.
I can connect to the printer and jog the axes from repeitier, but when I try to heat the extruder I get a M999 error. If I try to heat the bed the printer sounds error beeps over and over.
The LCD is out but I can press the buttons and hear corresponding beeps as I do. I removed the printer shell and the FF cable looks to be in perfect condition.
At this point I’m thinking maybe I crossed the thermistor wires, or the like causing a short.
My questions are:
Would causing a short here make the LCD go out?
What would make the LCD go out?
If it’s a short would there be something on the main board to be fixed? (I’ve read there is a fuse, etc.)
If there is a problem with the main board would I still get the (limited) functionality of the printer that I am getting?
I’ve thought of replacing the thermistor, but it appears that the 1.0a uses a 500K rather than the 100k for both the extruder and the heated bed. Before I get crazy with work arounds I’m hoping one of you can guide me to a simpler fix.
Thanks in advance
Hi was the printer on when you were playing with it? Only asking as did have repetier on mine but was playing around with the fan and i think the + wire hit the metal pices on the bed then i got the 2 black bars on the screen and only got get the z axle to work x y was frozen up still got it to content to repetier host try to reflash it but no good ended up putting a Arduino mega with ramps 1.4 board to get it working again. If it was on i am guess you have fry the board . Good luck let me know how you go whit it
jakel7
yes, It was on. I didn’t get black bars, I have no LCD at all. I have been told it is likely one ore more of the zero ohm resistors I probably shorted. At least I hope it’s not the whole mainboard. But then, I just tested them and they all read about 1.4ohms each, so I’m not sure what I’m going to do at this point.
I gave some thought to putting in the ramps/mega. how long have you been running that, and would you recommend it?
I’m not really too keen on taking that on right now but I do already have those parts on order, I was in the middle of printing the MPCNC when I screwed up my Da vinci.
I have had going for about 3 mouths now not had any real issue . Mine was second hand when I got it and never really got it to work when it was stock . But i did notice that I could control it a lot more better than with the stock software. I dont think you can use the CNC board on the printer . If your going to do the Adriuno mega you will need just look at it as a kit forget its a xyz lots of YouTube videos and if you are looking at doing a CNC you should be fine. Good luck with the project
