Is this correct… am I missing anything? … thanks…
START GCODE…
G28 ;home all axes
G1 Z0.2 F1200 ;raise nozzle
G92 E0 ;reset extrusion distance
G1 X100 Y0 E12 F600 ;purge nozzle
END GCODE…
M104 S0 ;turn off extruder/hotend heat
M140 S0 ;turn off bed heat
G91 ;relative positioning
G1 E-1 F300 ;retract the filament before lifting the nozzle to release some of the pressure
G1 Z+1 E-2 F300 ;move Z up and retract filament 2mm
G90 ;absolute positioning
G1 X20 Y115 F1000 ;move bed forward and hotend towards the tower
M84 ;disable motors
WIDTH: 120mm
DEPTH: 120mm
HEIGHT: 120mm
HEATED BED: checked
MACHINE CENTER IS ZERO: unchecked
GCODE FLAVOE: RepRap
XMIN: 75
YMIN: 18
XMAX: 18
YMAX: 35
MATERIAL DIAM: 1.75mm
NOZZLE SIZE: 0.4mm
GANTRY HEIGHT: 99999999999
