Hello all,
I recently purchased a Cubex Duo as my first 3D printer. I’ve managed to get several nice prints using Kisslicer, but I’ve had twice as many failed prints. I’m ready to begin modifications and go to a RAMPS controller as well as stiffen the bed and install a heatbed with a glass surface. I’ve seen only a couple of people doing mods to these things, so I’m hoping someone here can offer some advice on the best route to take on the modifications. The physical printer itself seems very nice especially since I bought it brand new for 1/10th the original price. I’m hoping the mods will unleash it’s capabilities.
  • I have already trashed the ridiculous filament cartridges and added external roll holders. I had to remove the filament tubes after the included filament kept breaking inside of them.
  • I bought a 300mm x 300mm MK2a heated bed and plan to build a more sturdy mount to install it to, I just need to get a glass printing surface.
  • I bought a Mean Well 450 watt 24 volt power supply to use independently for the heated bed.
** I haven’t taken the Cubex apart yet, but can I use the included power supply for the RAMPS board?
** Can I use the original stepper motors and extruders with the RAMPS board?
** Is a RAMPS board the best option or is there something better?
I’m watching YouTube videos on how to install RAMPS boards, drivers, etc., but if anyone has experience that they can offer, I would greatly appreciate feedback.
Thanks again!
Dan Cook
Greenville, SC
I can’t give much specific help, i’ve never used a Cubex. But after reading some reviews on them I think i’ve got some general things that might help…
a new control board won’t necessarily fix whatever was causing your failed prints. Make sure you’re calibrated as well as you can be for everything, bed leveling, Z Offsets, temperature sensors placed correctly, etc…
If there is a calibration error a new controller won’t fix it, but the process of installing a new controller will probably ensure you check each thing and it will get fixed :wink:
Marlin firmware is the only one I’ve used since moving out of the proprietary XYZ Printer realm and I love how much I can control with it. It works with just about every motor you can get, so although I’m not 100% sure about it, I would be very surprised if you can’t re-use your existing equipment. To the firmware it’s just about how many spins = how much physical space to move. You’ll set that up in your initial setup steps. You should be fine with it. Cubex made the hardware work (sort of) You should be able to as well. Just take your time and understand each part of your printer and each part of your firmware before moving onto the next thing. Just because you can make it work doesn’t really mean you “get it”. Work with it until you have your head wrapped around it and as problems come up you’ll be much better at fixing them.
Good luck, and keep at it :smiley:
-–edit—
Also for your bed, check out http://www.thingiverse.com/thing:6599. Put some springs around the screws holding your bed to the platform and it becomes SUPER easy to level again when it gets out-of-whack. Big Big time saver :smiley:
Thanks for your reponse, Travis.
That’s just the problem with the Cubex… the software and filament system are proprietary… leaving you with very few options. I’ve calibrated the machine as best as possible with the software, but the firmware controlling the printer is eventually going to realize my filament cartridges should be empty and turn it into a paper weight. As far as I know, there’s no way to do calibrations for e-steps, so I could never get the flow dialed in. I am still learning though. Ive learned enough so far that the stock controller and firmware have got to go!
I’m currently working on the bed. I’m adding a new bottom plate to mount the mk2a to.
Thanks again!
I don’t know much about your printer… But here is a link to someone doing the exact same conversion your trying to do
http://www.zatopa.com/blog/opencube-an-opensource-conversion-for-the-cubex-duo-firmware/
Upgrade the stepper drivers to DRV8825. I’ll post my Marlin config.h for you later tonight Go with optical end stops. Much easier to use.
Make sure your RAMPS shield has the higher voltage rated components. You will find that the z axis is still a pain. Driving that nema23 motor consistently at 19v is painful.
The steppers are ok but power hungry. Be sure to tune your stepper drivers. I’d also consider converting to E3D hotends and Bowden drive to make things easy. Direct drive with the stock components still creates issues.
Hi, I would like to comment on a couple of things. My disclaimer: I am not familiar with the Cubex and so will avoid any opinions regarding that machine.
1) I have discovered through research and personal experience that ordinary 3mm window glass works just as well as the vastly more expensive borosilicate glass. You can go to your local glass shop and have them cut a custom piece for a very small sum. Buy extras as you will likely break one or two along the way.
Most heated bed installations I have seen mount the heater to the frame on a spring loaded leveling mechanism of some sort. This can cause the heater PCB to warp and by association the glass bed clamped to it.
It seems to me this is akin to the tail wagging the dog. It works much better to make a mount that holds the glass to the frame and clamp the heater to the underside of the glass. In this way, warpage from the heater does not tend to warp the glass.
Also think about adding insulation to the underside of the bed heater to reduce energy requirements and improve heating time. It also helps maintain a more constant temperature.
2) I believe the RAMPS board is a 12V board. If your heaters are 12V then it’s a good match. If you intend on using 24V for heaters, there are several other print controllers available (Rambo, mini-Rambo, etc).
Note that a 12V (or even 24V) bed heater may not achieve your desired temperature. If you plan to do ABS with a bed temp of >100C you will need around 0.6W per cm^2. For a 30x30 bed you will need something around 540 watts. It may be better to use a bed heater driven from the AC main but that becomes more dangerous and problematic.
Good luck, John
Awesome! Another Cubex owner! I’m replying as best I can on this smart phone… I’ll dig deeper tomorrow when I can sit at my pc… I’d like to order some hardware ASAP, so thank you guys so much for making recommendations. CollectorCNC, I need to start following you. I’d like to build a CNC machine as soon as I get this 3D printer going… I’m assuming you know CNC as well due to your name. Thanks for offering your config.h!
I forgot about the RAMBO… I bought the Mean Well 450w 24v power supply to run independently for the heatbed. I thought I read somewhere that it would provide enough power. Good advice on the insulation. The mk2a heatbed/element isn’t exactly flat… I was thinking about using a sheet of aluminum roughly 300mm x 300mm as the bottom of my heatbed. It’ll be solidly mounted to the frame pieces coming from the rear supports. I think once I get some bolts and stiff springs at all four corners of the mk2a, it should flatten out. The only concern I had with solidly mounting the glass was the chance of a print sticking to the plate. Does it help to get high tensile glass? Thank you for all of the information!
Here’s the full config file. I have built my own CNC Router and several 3D printers, and would be happy to help if you have questions.
Key things to remember:
  • I’m using single extruder with E3D v6 hotend
  • my fans are either 100% on or off and all powered directly from the PS
  • steps are calibrated to my steppers (1.8 degree 1/16 micro stepping and 1/8th on the Z)
  • I’m using stock MXL pulleys and belts
  • I’m using the stock filament drive system (not ideal)
  • I run 2 360w 12v power supplies.
  • One PS for my heated bed and one for the arduino/RAMPS shield. (you can run the 24v bed from your 19v PS in bang bang mode by using a relay.)
  • I have auto bed leveling installed
  • The Nema23 stepper is fickel. Spend time setting things up properly.
  • Get some sheet plastic at hobby lobby or michaels and use it to seal up the big open windows, magnets glued to the inside of the case work great, and this helps keep that giant heated bed from cooling too much on the edges.
  • unscrew the pucks on the lid and flip around so the vent is closed off.
  • I probably forgot some stuff since I have a pretty solid setup now so if something doesn’t make sense, feel free to ask.
#include <U8glib.h>
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
#include “boards.h”
#include “macros.h”
//============================= Getting Started =============================
Here are some standard links for getting your machine calibrated:
* Calibration - RepRap
* Still Extruding: Calibrating XY&Z Step/MM - YouTube
* http://calculator.josefprusa.cz
* http://reprap.org/wiki/Triffid\_Hunter's\_Calibration\_Guide
* The Essential Calibration Set by coasterman - Thingiverse
* Calibration of your RepRap - StillExtruding
* XY 20 mm Calibration Box by whoisjoecarr - Thingiverse
// This configuration file contains the basic settings.
// Advanced settings can be found in Configuration_adv.h
// BASIC SETTINGS: select your board type, temperature sensor type, axis scaling, and endstop configuration
//============================= DELTA Printer ===============================
// For a Delta printer replace the configuration files with the files in the
// example_configurations/delta directory.
//============================= SCARA Printer ===============================
// For a Scara printer replace the configuration files with the files in the
// example_configurations/SCARA directory.
// @section info
#if ENABLED(USE_AUTOMATIC_VERSIONING)
#include “_Version.h”
#else
#include “Default_Version.h”
#endif
// User-specified version info of this build to display in [Pronterface, etc] terminal window during
// startup. Implementation of an idea by Prof Braino to inform user that any changes made to this
// build by the user have been successfully uploaded into firmware.
#define STRING_CONFIG_H_AUTHOR “( text here)” // Who made the changes.
#define SHOW_BOOTSCREEN
#define STRING_SPLASH_LINE1 SHORT_BUILD_VERSION // will be shown during bootup in line 1
#define STRING_SPLASH_LINE2 STRING_DISTRIBUTION_DATE // will be shown during bootup in line 2
// @section machine
// SERIAL_PORT selects which serial port should be used for communication with the host.
// This allows the connection of wireless adapters (for instance) to non-default port pins.
// Serial port 0 is still used by the Arduino bootloader regardless of this setting.
// :[0,1,2,3,4,5,6,7]
#define SERIAL_PORT 0
// This determines the communication speed of the printer
// :[2400,9600,19200,38400,57600,115200,250000]
#define BAUDRATE 250000
// Enable the Bluetooth serial interface on AT90USB devices
//#define BLUETOOTH
// The following define selects which electronics board you have.
// Please choose the name from boards.h that matches your setup
#ifndef MOTHERBOARD
#define MOTHERBOARD BOARD_RAMPS_14_EFB
#endif
// Optional custom name for your RepStrap or other custom machine
// Displayed in the LCD “Ready” message
#define CUSTOM_MACHINE_NAME “”
// Define this to set a unique identifier for this printer, (Used by some programs to differentiate between machines)
// You can use an online service to generate a random UUID. (eg Online UUID Generator Tool)
//#define MACHINE_UUID “00000000-0000-0000-0000-000000000000”
// This defines the number of extruders
// :[1,2,3,4]
#define EXTRUDERS 1
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
//#define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
//#define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis
//// The following define selects which power supply you have. Please choose the one that matches your setup
// 1 = ATX
// 2 = X-Box 360 203Watts (the blue wire connected to PS_ON and the red wire to VCC)
// :{1:‘ATX’,2:‘X-Box 360’}
#define POWER_SUPPLY 1
// Define this to have the electronics keep the power supply off on startup. If you don’t know what this is leave it.
//#define PS_DEFAULT_OFF
// @section temperature
//============================= Thermal Settings ============================
//–NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table
//// Temperature sensor settings:
// -2 is thermocouple with MAX6675 (only for sensor 0)
// -1 is thermocouple with AD595
// 0 is not used
// 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
// 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
// 3 is Mendel-parts thermistor (4.7k pullup)
// 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
// 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup)
// 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
// 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
// 71 is 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup)
// 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
// 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
// 10 is 100k RS thermistor 198-961 (4.7k pullup)
// 11 is 100k beta 3950 1% thermistor (4.7k pullup)
// 12 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed)
// 13 is 100k Hisens 3950 1% up to 300°C for hotend "Simple ONE " & "Hotend “All In ONE”
// 20 is the PT100 circuit found in the Ultimainboard V2.x
// 60 is 100k Maker’s Tool Works Kapton Bed Thermistor beta=3950
// 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k
// (but gives greater accuracy and more stable PID)
// 51 is 100k thermistor - EPCOS (1k pullup)
// 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
// 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup)
// 1047 is Pt1000 with 4k7 pullup
// 1010 is Pt1000 with 1k pullup (non standard)
// 147 is Pt100 with 4k7 pullup
// 110 is Pt100 with 1k pullup (non standard)
// 998 and 999 are Dummy Tables. They will ALWAYS read 25°C or the temperature defined below.
// Use it for Testing or Development purposes. NEVER for production machine.
//#define DUMMY_THERMISTOR_998_VALUE 25
//#define DUMMY_THERMISTOR_999_VALUE 100
// :{ ‘0’: “Not used”, ‘4’: “10k !! do not use for a hotend. Bad resolution at high temp. !!”, ‘1’: “100k / 4.7k - EPCOS”, ‘51’: “100k / 1k - EPCOS”, ‘6’: “100k / 4.7k EPCOS - Not as accurate as Table 1”, ‘5’: “100K / 4.7k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)”, ‘7’: “100k / 4.7k Honeywell 135-104LAG-J01”, ‘71’: “100k / 4.7k Honeywell 135-104LAF-J01”, ‘8’: “100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT”, ‘9’: “100k / 4.7k GE Sensing AL03006-58.2K-97-G1”, ‘10’: “100k / 4.7k RS 198-961”, ‘11’: “100k / 4.7k beta 3950 1%”, ‘12’: “100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT (calibrated for Makibox hot bed)”, ‘13’: “100k Hisens 3950 1% up to 300°C for hotend 'Simple ONE ’ & hotend ‘All In ONE’”, ‘60’: “100k Maker’s Tool Works Kapton Bed Thermistor beta=3950”, ‘55’: “100k / 1k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)”, ‘2’: “200k / 4.7k - ATC Semitec 204GT-2”, ‘52’: “200k / 1k - ATC Semitec 204GT-2”, ‘-2’: “Thermocouple + MAX6675 (only for sensor 0)”, ‘-1’: “Thermocouple + AD595”, ‘3’: “Mendel-parts / 4.7k”, ‘1047’: “Pt1000 / 4.7k”, ‘1010’: “Pt1000 / 1k (non standard)”, ‘20’: “PT100 (Ultimainboard V2.x)”, ‘147’: “Pt100 / 4.7k”, ‘110’: “Pt100 / 1k (non-standard)”, ‘998’: “Dummy 1”, ‘999’: “Dummy 2” }
#define TEMP_SENSOR_0 5
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_BED 11
// This makes temp sensor 1 a redundant sensor for sensor 0. If the temperatures difference between these sensors is to high the print will be aborted.
//#define TEMP_SENSOR_1_AS_REDUNDANT
#define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10
// Actual temperature must be close to target for this long before M109 returns success
#define TEMP_RESIDENCY_TIME 10 // (seconds)
#define TEMP_HYSTERESIS 3 // (degC) range of +/- temperatures considered “close” to the target one
#define TEMP_WINDOW 1 // (degC) Window around target to start the residency timer x degC early.
// The minimal temperature defines the temperature below which the heater will not be enabled It is used
// to check that the wiring to the thermistor is not broken.
// Otherwise this would lead to the heater being powered on all the time.
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 5
#define HEATER_2_MINTEMP 5
#define HEATER_3_MINTEMP 5
#define BED_MINTEMP 5
// When temperature exceeds max temp, your heater will be switched off.
// This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure!
// You should use MINTEMP for thermistor short/failure protection.
#define HEATER_0_MAXTEMP 275
#define HEATER_1_MAXTEMP 275
#define HEATER_2_MAXTEMP 275
#define HEATER_3_MAXTEMP 275
#define BED_MAXTEMP 115
// If your bed has low resistance e.g. .6 ohm and throws the fuse you can duty cycle it to reduce the
// average current. The value should be an integer and the heat bed will be turned on for 1 interval of
// HEATER_BED_DUTY_CYCLE_DIVIDER intervals.
//#define HEATER_BED_DUTY_CYCLE_DIVIDER 4
// If you want the M105 heater power reported in watts, define the BED_WATTS, and (shared for all extruders) EXTRUDER_WATTS
//#define EXTRUDER_WATTS (12.0*12.0/6.7) // P=I^2/R
//#define BED_WATTS (12.0*12.0/1.1) // P=I^2/R
//============================= PID Settings ================================
// PID Tuning Guide here: http://reprap.org/wiki/PID\_Tuning
// Comment the following line to disable PID and enable bang-bang.
#define PIDTEMP
#define BANG_MAX 255 // limits current to nozzle while in bang-bang mode; 255=full current
#define PID_MAX BANG_MAX // limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current
#if ENABLED(PIDTEMP)
//#define PID_DEBUG // Sends debug data to the serial port.
//#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX
//#define SLOW_PWM_HEATERS // PWM with very low frequency (roughly 0.125Hz=8s) and minimum state time of approximately 1s useful for heaters driven by a relay
//#define PID_PARAMS_PER_EXTRUDER // Uses separate PID parameters for each extruder (useful for mismatched extruders)
// Set/get with gcode: M301 E[extruder number, 0-2]
#define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature
// is more then PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max.
#define PID_INTEGRAL_DRIVE_MAX PID_MAX //limit for the integral term
#define K1 0.95 //smoothing factor within the PID
// If you are using a pre-configured hotend then you can use one of the value sets by uncommenting it
// Prusa i3 E3D v6
#define DEFAULT_Kp 22.2
#define DEFAULT_Ki 1.08
#define DEFAULT_Kd 114
// MakerGear
//#define DEFAULT_Kp 7.0
//#define DEFAULT_Ki 0.1
//#define DEFAULT_Kd 12
// Mendel Parts V9 on 12V
//#define DEFAULT_Kp 63.0
//#define DEFAULT_Ki 2.25
//#define DEFAULT_Kd 440
#endif // PIDTEMP
//============================= PID > Bed Temperature Control ===============
// Select PID or bang-bang with PIDTEMPBED. If bang-bang, BED_LIMIT_SWITCHING will enable hysteresis
// Uncomment this to enable PID on the bed. It uses the same frequency PWM as the extruder.
// If your PID_dT is the default, and correct for your hardware/configuration, that means 7.689Hz,
// which is fine for driving a square wave into a resistive load and does not significantly impact you FET heating.
// This also works fine on a Fotek SSR-10DA Solid State Relay into a 250W heater.
// If your configuration is significantly different than this and you don’t understand the issues involved, you probably
// shouldn’t use bed PID until someone else verifies your hardware works.
// If this is enabled, find your own PID constants below.
//#define PIDTEMPBED
//#define BED_LIMIT_SWITCHING
// This sets the max power delivered to the bed, and replaces the HEATER_BED_DUTY_CYCLE_DIVIDER option.
// all forms of bed control obey this (PID, bang-bang, bang-bang with hysteresis)
// setting this to anything other than 255 enables a form of PWM to the bed just like HEATER_BED_DUTY_CYCLE_DIVIDER did,
// so you shouldn’t use it unless you are OK with PWM on your bed. (see the comment on enabling PIDTEMPBED)
#define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current
//#define PID_BED_DEBUG // Sends debug data to the serial port.
#if ENABLED(PIDTEMPBED)
#define PID_BED_INTEGRAL_DRIVE_MAX MAX_BED_POWER //limit for the integral term
//120v 250W silicone heater into 4mm borosilicate (MendelMax 1.5+)
//from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, aggressive factor of .15 (vs .1, 1, 10)
#define DEFAULT_bedKp 10.00
#define DEFAULT_bedKi .023
#define DEFAULT_bedKd 305.4
//from pidautotune
//#define DEFAULT_bedKp 97.1
//#define DEFAULT_bedKi 1.41
//#define DEFAULT_bedKd 1675.16
// FIND YOUR OWN: “M303 E-1 C8 S90” to run autotune on the bed at 90 degreesC for 8 cycles.
#endif // PIDTEMPBED
// @section extruder
//this prevents dangerous Extruder moves, i.e. if the temperature is under the limit
//can be software-disabled for whatever purposes by
#define PREVENT_DANGEROUS_EXTRUDE
//if PREVENT_DANGEROUS_EXTRUDE is on, you can still disable (uncomment) very long bits of extrusion separately.
#define PREVENT_LENGTHY_EXTRUDE
#define EXTRUDE_MINTEMP 180
#define EXTRUDE_MAXLENGTH (X_MAX_LENGTH+Y_MAX_LENGTH) //prevent extrusion of very large distances.
//======================== Thermal Runaway Protection =======================
* Thermal Runaway Protection protects your printer from damage and fire if a
* thermistor falls out or temperature sensors fail in any way.
* The issue: If a thermistor falls out or a temperature sensor fails,
* Marlin can no longer sense the actual temperature. Since a disconnected
* thermistor reads as a low temperature, the firmware will keep the heater on.
* The solution: Once the temperature reaches the target, start observing.
* If the temperature stays too far below the target (hysteresis) for too long,
* the firmware will halt as a safety precaution.
#define THERMAL_PROTECTION_HOTENDS // Enable thermal protection for all extruders
//#define THERMAL_PROTECTION_BED // Enable thermal protection for the heated bed
//============================= Mechanical Settings =========================
// @section machine
// Uncomment this option to enable CoreXY kinematics
//#define COREXY
// Uncomment this option to enable CoreXZ kinematics
//#define COREXZ
// Enable this option for Toshiba steppers
//#define CONFIG_STEPPERS_TOSHIBA
// @section homing
// coarse Endstop Settings
//#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#if DISABLED(ENDSTOPPULLUPS)
// fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined
//#define ENDSTOPPULLUP_XMAX
//#define ENDSTOPPULLUP_YMAX
//#define ENDSTOPPULLUP_ZMAX
#define ENDSTOPPULLUP_XMIN
#define ENDSTOPPULLUP_YMIN
#define ENDSTOPPULLUP_ZMIN
#define ENDSTOPPULLUP_ZMIN_PROBE
#endif
// Mechanical endstop with COM to ground and NC to Signal uses “false” here (most common setup).
const bool X_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MIN_PROBE_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
#define DISABLE_MAX_ENDSTOPS
//#define DISABLE_MIN_ENDSTOPS
// If you want to enable the Z probe pin, but disable its use, uncomment the line below.
// This only affects a Z probe endstop if you have separate Z min endstop as well and have
// activated Z_MIN_PROBE_ENDSTOP below. If you are using the Z Min endstop on your Z probe,
// this has no effect.
//#define DISABLE_Z_MIN_PROBE_ENDSTOP
// For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1
// :{0:‘Low’,1:‘High’}
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis when it’s not being used.
// WARNING: When motors turn off there is a chance of losing position accuracy!
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define DISABLE_E false // For all extruders
#define DISABLE_INACTIVE_EXTRUDER true //disable only inactive extruders and keep active extruder enabled
// @section machine
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
#define INVERT_X_DIR true
#define INVERT_Y_DIR false
#define INVERT_Z_DIR true
// For direct drive extruder v9 set to true, for geared extruder set to false.
#define INVERT_E0_DIR true
#define INVERT_E1_DIR false
#define INVERT_E2_DIR false
#define INVERT_E3_DIR false
// @section homing
// ENDSTOP SETTINGS:
// Sets direction of endstops when homing; 1=MAX, -1=MIN
// :[-1,1]
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops false // If true, axis won’t move to coordinates less than HOME_POS.
#define max_software_endstops true // If true, axis won’t move to coordinates greater than the defined lengths below.
// @section machine
// Travel limits after homing (units are in mm)
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define X_MAX_POS 200
#define Y_MAX_POS 200
#define Z_MAX_POS 200
//========================= Filament Runout Sensor ==========================
//#define FILAMENT_RUNOUT_SENSOR // Uncomment for defining a filament runout sensor such as a mechanical or opto endstop to check the existence of filament
// In RAMPS uses servo pin 2. Can be changed in pins file. For other boards pin definition should be made.
// It is assumed that when logic high = filament available
// when logic low = filament ran out
#if ENABLED(FILAMENT_RUNOUT_SENSOR)
const bool FIL_RUNOUT_INVERTING = true; // Should be uncommented and true or false should assigned
#define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined.
#define FILAMENT_RUNOUT_SCRIPT “M600”
#endif
//=========================== Manual Bed Leveling ===========================
//#define MANUAL_BED_LEVELING // Add display menu option for bed leveling.
//#define MESH_BED_LEVELING // Enable mesh bed leveling.
#if ENABLED(MANUAL_BED_LEVELING)
#define MBL_Z_STEP 0.025 // Step size while manually probing Z axis.
#endif // MANUAL_BED_LEVELING
#if ENABLED(MESH_BED_LEVELING)
#define MESH_MIN_X 10
#define MESH_MAX_X (X_MAX_POS - MESH_MIN_X)
#define MESH_MIN_Y 10
#define MESH_MAX_Y (Y_MAX_POS - MESH_MIN_Y)
#define MESH_NUM_X_POINTS 3 // Don’t use more than 7 points per axis, implementation limited.
#define MESH_NUM_Y_POINTS 3
#define MESH_HOME_SEARCH_Z 4 // Z after Home, bed somewhere below but above 0.0.
#endif // MESH_BED_LEVELING
//============================ Bed Auto Leveling ============================
// @section bedlevel
#define AUTO_BED_LEVELING_FEATURE // Delete the comment to enable (remove // at the start of the line)
//#define DEBUG_LEVELING_FEATURE
#define Z_MIN_PROBE_REPEATABILITY_TEST // If not commented out, Z-Probe Repeatability test will be included if Auto Bed Leveling is Enabled.
#if ENABLED(AUTO_BED_LEVELING_FEATURE)
// There are 2 different ways to specify probing locations:
// - “grid” mode
// Probe several points in a rectangular grid.
// You specify the rectangle and the density of sample points.
// This mode is preferred because there are more measurements.
// - “3-point” mode
// Probe 3 arbitrary points on the bed (that aren’t colinear)
// You specify the XY coordinates of all 3 points.
// Enable this to sample the bed in a grid (least squares solution).
// Note: this feature generates 10KB extra code size.
#define AUTO_BED_LEVELING_GRID
#if ENABLED(AUTO_BED_LEVELING_GRID)
#define LEFT_PROBE_BED_POSITION 5
#define RIGHT_PROBE_BED_POSITION 175
#define FRONT_PROBE_BED_POSITION 18
#define BACK_PROBE_BED_POSITION 190
#define MIN_PROBE_EDGE 10 // The Z probe minimum square sides can be no smaller than this.
// Set the number of grid points per dimension.
// You probably don’t need more than 3 (squared=9).
#define AUTO_BED_LEVELING_GRID_POINTS 2
#else // !AUTO_BED_LEVELING_GRID
// Arbitrary points to probe.
// A simple cross-product is used to estimate the plane of the bed.
#define ABL_PROBE_PT_1_X 15
#define ABL_PROBE_PT_1_Y 180
#define ABL_PROBE_PT_2_X 15
#define ABL_PROBE_PT_2_Y 20
#define ABL_PROBE_PT_3_X 170
#define ABL_PROBE_PT_3_Y 20
#endif // AUTO_BED_LEVELING_GRID
// Offsets to the Z probe relative to the nozzle tip.
// X and Y offsets must be integers.
#define X_PROBE_OFFSET_FROM_EXTRUDER -22 // Z probe to nozzle X offset: -left +right
#define Y_PROBE_OFFSET_FROM_EXTRUDER -3 // Z probe to nozzle Y offset: -front +behind
#define Z_PROBE_OFFSET_FROM_EXTRUDER -6 // Z probe to nozzle Z offset: -below (always!)
#define Z_RAISE_BEFORE_HOMING 8 // (in mm) Raise Z axis before homing (G28) for Z probe clearance.
// Be sure you have this distance over your Z_MAX_POS in case.
#define XY_TRAVEL_SPEED 4000 // X and Y axis travel speed between probes, in mm/min.
#define Z_RAISE_BEFORE_PROBING 8 // How much the Z axis will be raised before traveling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 5 // How much the Z axis will be raised when traveling from between next probing points.
#define Z_RAISE_AFTER_PROBING 8 // How much the Z axis will be raised after the last probing point.
//#define Z_PROBE_END_SCRIPT “G1 Z10 F12000\nG1 X15 Y330\nG1 Z0.5\nG1 Z10” // These commands will be executed in the end of G29 routine.
// Useful to retract a deployable Z probe.
//#define Z_PROBE_SLED // Turn on if you have a Z probe mounted on a sled like those designed by Charles Bell.
//#define SLED_DOCKING_OFFSET 5 // The extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you’d like.
//If you have enabled the Bed Auto Leveling and are using the same Z Probe for Z Homing,
//it is highly recommended you let this Z_SAFE_HOMING enabled!!!
#define Z_SAFE_HOMING // This feature is meant to avoid Z homing with Z probe outside the bed area.
// When defined, it will:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled.
// - If stepper drivers timeout, it will need X and Y homing again before Z homing.
// - Position the Z probe in a defined XY point before Z Homing when homing all axis (G28).
// - Block Z homing only when the Z probe is outside bed area.
#if ENABLED(Z_SAFE_HOMING)
#define Z_SAFE_HOMING_X_POINT ((X_MIN_POS + X_MAX_POS) / 2) // X point for Z homing when homing all axis (G28).
#define Z_SAFE_HOMING_Y_POINT ((Y_MIN_POS + Y_MAX_POS) / 2) // Y point for Z homing when homing all axis (G28).
#endif
// Support for a dedicated Z probe endstop separate from the Z min endstop.
// If you would like to use both a Z probe and a Z min endstop together,
// uncomment #define Z_MIN_PROBE_ENDSTOP and read the instructions below.
// If you still want to use the Z min endstop for homing, disable Z_SAFE_HOMING above.
// Example: To park the head outside the bed area when homing with G28.
// WARNING:
// The Z min endstop will need to set properly as it would without a Z probe
// to prevent head crashes and premature stopping during a print.
// To use a separate Z probe endstop, you must have a Z_MIN_PROBE_PIN
// defined in the pins_XXXXX.h file for your control board.
// If you are using a servo based Z probe, you will need to enable NUM_SERVOS,
// Z_ENDSTOP_SERVO_NR and SERVO_ENDSTOP_ANGLES in the R/C SERVO support below.
// RAMPS 1.3/1.4 boards may be able to use the 5V, Ground and the D32 pin
// in the Aux 4 section of the RAMPS board. Use 5V for powered sensors,
// otherwise connect to ground and D32 for normally closed configuration
// and 5V and D32 for normally open configurations.
// Normally closed configuration is advised and assumed.
// The D32 pin in Aux 4 on RAMPS maps to the Arduino D32 pin.
// Z_MIN_PROBE_PIN is setting the pin to use on the Arduino.
// Since the D32 pin on the RAMPS maps to D32 on Arduino, this works.
// D32 is currently selected in the RAMPS 1.3/1.4 pin file.
// All other boards will need changes to the respective pins_XXXXX.h file.
// WARNING:
// Setting the wrong pin may have unexpected and potentially disastrous outcomes.
// Use with caution and do your homework.
//#define Z_MIN_PROBE_ENDSTOP
#endif // AUTO_BED_LEVELING_FEATURE
// @section homing
// The position of the homing switches
//#define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used
//#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0)
// Manual homing switch locations:
// For deltabots this means top and center of the Cartesian print volume.
#if ENABLED(MANUAL_HOME_POSITIONS)
#define MANUAL_X_HOME_POS 0
#define MANUAL_Y_HOME_POS 0
#define MANUAL_Z_HOME_POS 0
//#define MANUAL_Z_HOME_POS 402 // For delta: Distance between nozzle and print surface after homing.
#endif
// @section movement
* MOVEMENT SETTINGS
#define HOMING_FEEDRATE {34*60, 34*60, 1.5*60, 0} // set the homing speeds (mm/min)
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {99.93,100.37,4053,162.32} // default steps per unit
#define DEFAULT_MAX_FEEDRATE {500, 500, 2, 25} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {3000,3000,100,2000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 2000 // X, Y, Z and E acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 2000 // E acceleration in mm/s^2 for retracts
#define DEFAULT_TRAVEL_ACCELERATION 1000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves
// The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously)
#define DEFAULT_XYJERK 10.0 // (mm/sec)
#define DEFAULT_ZJERK 0.4 // (mm/sec)
#define DEFAULT_EJERK 5.0 // (mm/sec)
//============================= Additional Features ===========================
// @section more
// Custom M code points
#define CUSTOM_M_CODES
#if ENABLED(CUSTOM_M_CODES)
#define CUSTOM_M_CODE_SET_Z_PROBE_OFFSET 851
#define Z_PROBE_OFFSET_RANGE_MIN -20
#define Z_PROBE_OFFSET_RANGE_MAX 20
#endif
#endif
// @section extras
// EEPROM
// The microcontroller can store settings in the EEPROM, e.g. max velocity…
// M500 - stores parameters in EEPROM
// M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
// M502 - reverts to the default “factory settings”. You still need to store them in EEPROM afterwards if you want to.
//define this to enable EEPROM support
//#define EEPROM_SETTINGS
#if ENABLED(EEPROM_SETTINGS)
// To disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out:
//#define EEPROM_CHITCHAT // Please keep turned on if you can.
#endif
// M100 Free Memory Watcher
//#define M100_FREE_MEMORY_WATCHER // uncomment to add the M100 Free Memory Watcher for debug purpose
// Preheat Constants
#define PLA_PREHEAT_HOTEND_TEMP 180
#define PLA_PREHEAT_HPB_TEMP 70
#define PLA_PREHEAT_FAN_SPEED 0 // Insert Value between 0 and 255
#define ABS_PREHEAT_HOTEND_TEMP 240
#define ABS_PREHEAT_HPB_TEMP 70
#define ABS_PREHEAT_FAN_SPEED 0 // Insert Value between 0 and 255
//==============================LCD and SD support=============================
// @section lcd
// Define your display language below. Replace (en) with your language code and uncomment.
// en, pl, fr, de, es, ru, bg, it, pt, pt-br, fi, an, nl, ca, eu, kana, kana_utf8, cn, test
// See also language.h
#define LANGUAGE_INCLUDE GENERATE_LANGUAGE_INCLUDE(en)
// Choose ONE of these 3 charsets. This has to match your hardware. Ignored for full graphic display.
// To find out what type you have - compile with (test) - upload - click to get the menu. You’ll see two typical lines from the upper half of the charset.
// See also documentation/LCDLanguageFont.md
#define DISPLAY_CHARSET_HD44780_JAPAN // this is the most common hardware
//#define DISPLAY_CHARSET_HD44780_WESTERN
//#define DISPLAY_CHARSET_HD44780_CYRILLIC
//#define ULTRA_LCD //general LCD support, also 16x2
//#define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family)
#define SDSUPPORT // Enable SD Card Support in Hardware Console
// Changed behaviour! If you need SDSUPPORT uncomment it!
//#define SDSLOW // Use slower SD transfer mode (not normally needed - uncomment if you’re getting volume init error)
//#define SDEXTRASLOW // Use even slower SD transfer mode (not normally needed - uncomment if you’re getting volume init error)
#define SD_CHECK_AND_RETRY // Use CRC checks and retries on the SD communication
#define ENCODER_PULSES_PER_STEP 1 // Increase if you have a high resolution encoder
#define ENCODER_STEPS_PER_MENU_ITEM 5 // Set according to ENCODER_PULSES_PER_STEP or your liking
//#define ULTIMAKERCONTROLLER //as available from the Ultimaker online store.
//#define ULTIPANEL //the UltiPanel as on Thingiverse
//#define SPEAKER // The sound device is a speaker - not a buzzer. A buzzer resonates with his own frequency.
#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100 // the duration the buzzer plays the UI feedback sound. ie Screen Click
#define LCD_FEEDBACK_FREQUENCY_HZ 1000 // this is the tone frequency the buzzer plays when on UI feedback. ie Screen Click
// 0 to disable buzzer feedback. Test with M300 S P
// PanelOne from T3P3 (via RAMPS 1.4 AUX2/AUX3)
// PanelOne - RepRap
//#define PANEL_ONE
// The MaKr3d Makr-Panel with graphic controller and SD support
// http://reprap.org/wiki/MaKr3d\_MaKrPanel
//#define MAKRPANEL
// The Panucatt Devices Viki 2.0 and mini Viki with Graphic LCD
// http://panucatt.com
// ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: http://code.google.com/p/u8glib/wiki/u8glib
//#define VIKI2
//#define miniVIKI
// This is a new controller currently under development. GitHub - eboston/Adafruit-ST7565-Full-Graphic-Controller: 3D Printer Controller based around the Adafruit ST7565 display
//#define ELB_FULL_GRAPHIC_CONTROLLER
//#define SD_DETECT_INVERTED
// The RepRapDiscount Smart Controller (white PCB)
// http://reprap.org/wiki/RepRapDiscount\_Smart\_Controller
//#define REPRAP_DISCOUNT_SMART_CONTROLLER
// The GADGETS3D G3D LCD/SD Controller (blue PCB)
// http://reprap.org/wiki/RAMPS\_1.3/1.4\_GADGETS3D\_Shield\_with\_Panel
//#define G3D_PANEL
// The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PCB)
// http://reprap.org/wiki/RepRapDiscount\_Full\_Graphic\_Smart\_Controller
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// The RepRapWorld REPRAPWORLD_KEYPAD v1.1
// Welcome to reprapworld.com | 3D printing experts | ReprapWorld USA
//#define REPRAPWORLD_KEYPAD
//#define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0 // how much should be moved when a key is pressed, eg 10.0 means 10mm per click
// The Elefu RA Board Control Panel
// http://www.elefu.com/index.php?route=product/product&product\_id=53
// REMEMBER TO INSTALL LiquidCrystal_I2C.h in your ARDUINO library folder: https://github.com/kiyoshigawa/LiquidCrystal\_I2C
//#define RA_CONTROL_PANEL
// The MakerLab Mini Panel with graphic controller and SD support
// http://reprap.org/wiki/Mini\_panel
//#define MINIPANEL
* I2C Panels
//#define LCD_I2C_SAINSMART_YWROBOT
// PANELOLU2 LCD with status LEDs, separate encoder and click inputs
// This uses the LiquidTWI2 library v1.2.3 or later ( GitHub - lincomatic/LiquidTWI2: A lean, high speed I2C LCD Library for Arduino, which supports MCP23008 and MCP23017 )
// Make sure the LiquidTWI2 directory is placed in the Arduino or Sketchbook libraries subdirectory.
// (v1.2.3 no longer requires you to define PANELOLU in the LiquidTWI2.h library header file)
// Note: The PANELOLU2 encoder click input can either be directly connected to a pin
// (if BTN_ENC defined to != -1) or read through I2C (when BTN_ENC == -1).
//#define LCD_I2C_PANELOLU2
// Panucatt VIKI LCD with status LEDs, integrated click & L/R/U/P buttons, separate encoder inputs
//#define LCD_I2C_VIKI
// SSD1306 OLED generic display support
//#define U8GLIB_SSD1306
// Shift register panels
// 2 wire Non-latching LCD SR from:
// https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/schematics#!shiftregister-connection
// LCD configuration: http://reprap.org/wiki/SAV\_3D\_LCD
//#define SAV_3DLCD
// @section extras
// Increase the FAN pwm frequency. Removes the PWM noise but increases heating in the FET/Arduino
//#define FAST_PWM_FAN
// Use software PWM to drive the fan, as for the heaters. This uses a very low frequency
// which is not as annoying as with the hardware PWM. On the other hand, if this frequency
// is too low, you should also increment SOFT_PWM_SCALE.
//#define FAN_SOFT_PWM
// Incrementing this by 1 will double the software PWM frequency,
// affecting heaters, and the fan if FAN_SOFT_PWM is enabled.
// However, control resolution will be halved for each increment;
// at zero value, there are 128 effective control positions.
#define SOFT_PWM_SCALE 0
// Temperature status LEDs that display the hotend and bet temperature.
// If all hotends and bed temperature and temperature setpoint are < 54C then the BLUE led is on.
// Otherwise the RED led is on. There is 1C hysteresis.
//#define TEMP_STAT_LEDS
// M240 Triggers a camera by emulating a Canon RC-1 Remote
// Data from: http://www.doc-diy.net/photo/rc-1\_hacked/
//#define PHOTOGRAPH_PIN 23
// SkeinForge sends the wrong arc g-codes when using Arc Point as fillet procedure
//#define SF_ARC_FIX
// Support for the BariCUDA Paste Extruder.
//#define BARICUDA
//define BlinkM/CyzRgb Support
//#define BLINKM
\* R/C SERVO support
\* Sponsored by TrinityLabs, Reworked by codexmas
// Number of servos
// If you select a configuration below, this will receive a default value and does not need to be set manually
// set it manually if you have more servos than extruders and wish to manually control some
// leaving it undefined or defining as 0 will disable the servo subsystem
// If unsure, leave commented / disabled
#define NUM_SERVOS 1 // Servo index starts with 0 for M280 command
// Servo Endstops
// This allows for servo actuated endstops, primary usage is for the Z Axis to eliminate calibration or bed height changes.
// Use M851 to set the Z probe vertical offset from the nozzle. Store that setting with M500.
#define X_ENDSTOP_SERVO_NR -1
#define Y_ENDSTOP_SERVO_NR -1
#define Z_ENDSTOP_SERVO_NR 0
#define SERVO_ENDSTOP_ANGLES {{0,0}, {0,0}, {13,110}} // X,Y,Z Axis Extend and Retract angles
// Servo deactivation
// With this option servos are powered only during movement, then turned off to prevent jitter.
#define DEACTIVATE_SERVOS_AFTER_MOVE
#if ENABLED(DEACTIVATE_SERVOS_AFTER_MOVE)
// Delay (in microseconds) before turning the servo off. This depends on the servo speed.
// 300ms is a good value but you can try less delay.
// If the servo can’t reach the requested position, increase it.
#define SERVO_DEACTIVATION_DELAY 300
#endif
* Support for a filament diameter sensor
* Also allows adjustment of diameter at print time (vs at slicing)
* Single extruder only at this point (extruder 0)
* Motherboards
* 34 - RAMPS1.4 - uses Analog input 5 on the AUX2 connector
* 81 - Printrboard - Uses Analog input 2 on the Exp1 connector (version B,C,D,E)
* 301 - Rambo - uses Analog input 3
* Note may require analog pins to be defined for different motherboards
// Uncomment below to enable
//#define FILAMENT_SENSOR
#define FILAMENT_SENSOR_EXTRUDER_NUM 0 //The number of the extruder that has the filament sensor (0,1,2)
#define MEASUREMENT_DELAY_CM 14 //measurement delay in cm. This is the distance from filament sensor to middle of barrel
#define DEFAULT_NOMINAL_FILAMENT_DIA 3.00 //Enter the diameter (in mm) of the filament generally used (3.0 mm or 1.75 mm) - this is then used in the slicer software. Used for sensor reading validation
#define MEASURED_UPPER_LIMIT 3.30 //upper limit factor used for sensor reading validation in mm
#define MEASURED_LOWER_LIMIT 1.90 //lower limit factor for sensor reading validation in mm
#define MAX_MEASUREMENT_DELAY 20 //delay buffer size in bytes (1 byte = 1cm)- limits maximum measurement delay allowable (must be larger than MEASUREMENT_DELAY_CM and lower number saves RAM)
//defines used in the code
#define DEFAULT_MEASURED_FILAMENT_DIA DEFAULT_NOMINAL_FILAMENT_DIA //set measured to nominal initially
//When using an LCD, uncomment the line below to display the Filament sensor data on the last line instead of status. Status will appear for 5 sec.
//#define FILAMENT_LCD_DISPLAY
#include “Configuration_adv.h”
#include “thermistortables.h”
#endif //CONFIGURATION_H
Thanks again, Nate!
Others have mentioned the RAMBO, and to be honest, I haven’t really compared it to RAMPS, or whatever else is out there. I’ll just order exactly what you have and use your configuration since it obviously works for you, and the fact that I’m clueless to setting up the software at this point. Gotta learn somewhere. I was checking out the Bowden extruder setup the other day, and it looks promising. I imagine removing some weight from the Y axis is a good thing. I’ll probably put that off until I get the printer functioning again… I’ll 3D print (if possible) one of the setups I was looking at.
I really appreciate you taking the time to help me out! Hopefully I’ll have this thing up and running soon enough!
You’re welcome. If you’re having any trouble with configuration, we can connect on google hangouts to walk through things too.
Cork on top of the aluminum bed you have will allow you to place the pcb on top. then drop 8mm glass on top. Couple of clamps and a nice leveling job and you’re all set.
Plus the slot in the middle is a great way to clear your thermistor wiring
I ripped the original bottom plat out because the heated element hangs over each side. I’m going to replace it with an aluminum plate just a tad bigger than the element, so roughly 310 x 310. I’m debating whether to mount it to the Z frame solidly and use bolts/springs on the MK2a itself for leveling, or maybe use a seperate piece of aluminum under the element with cork insulation and use it for leveling. I don’t want to make it too heavy either case.
I spent the entire day reading about controllers, and I think I’m going to go with the Smoothieboard. Any debate on those boards? From what I’ve read and the videos I watched, it’s not a bad option for a beginner.
I’m going to try and order everything I need on Friday. I’m just assuming my stepper motors will work for now… but there’s a good chance that I may scrap the hot end for an upgrade.
I added a post a little while ago with a picture, but I don’t see it in the thread.
If you’re going the route of adding a solid plate, I’d take the time to get it drilled out to the correct dimension and continue to use the built in 3 point leveling system. Leveling can painful, but 3 points is way better than 4 in my opinion, because you get less interaction than the 4 point system for each adjustment you make. I purchased a sheet of cut and ground glass that was just a hair thinner than the stock glass bed, but you can actually just remove the white plastic crap from the glass if you don’t want to buy new, and the aluminum alignment piece will pop right off if you give it a light to medium whack with a small hammer or adjustable wrench. I have the auto bed leveling setup installed on mine so I switch between them when I am doing back to back prints.
Make sure that you plan out your wiring paths also. Think about using a flat ribbon, or you can do what I did, mount a terminal in a convenient place so that you can easily connect and disconnect the heavy gauge wires without tearing into the printer. A deans connector from your local hobby shop also works great to allow a quick disconnect that you can use to remove PCB completely if you need to.
I agree with you on the smoothieboard. I don’t have one, but I really like how they work. There should be no issue with your steppers and that board. Just be sure to read up on how to test your pairs on the stepper to ensure everything moves on the first try. I would go to matterhackers.com right away, they have 24V and 12V E3D hotends on sale this week. The V6 is a great hotend and is simple to use and prints super clean!
You’re right about the three point system. The stock plate was never level at the corners between prints when I replaced the build plate, but it was much easier to level. I was planning to replace the current bottom plate and use the three points as a mount, and I could always keep the bolts/springs there for leveling. I talked with Elias Bakken a good bit today about his controller, the Replicape and the control screen called Manga Screen. It looks promising… maybe a little challenging to figure out. I meant to ask you… I never really payed it much attention, but I wonder if the end stop switches currently on the Cubex are usable… are they optical or magnetic? I haven’t checked the internet.
They’re magnetic. There’s some good printable parts for doing an optical switch on thingiverse. Also check out cubexupgrades.com. They have some good parts that will save you some time completing your project.
OK, so I took the leap and ordered a Replicape, Manga Screen, and a Beaglebone this morning. Unfortunately the Replicape won’t be ready for delivery until later this month. It’ll just give me time to study G-Code and build a new computer since my old one is… old… Anyways… I did some research on the stock stepper motors in the Cubex, so I’m going to add some details in case this thread is ever useful for anyone. I was told to keep my steppers above 1.5A or they could possibly be noisy. The amperage seems to be acceptable with these steppers, so I’m not going to swap them unless they give me issues.
X,Y axis: M42STH47-1684SC-S (NEMA 17) (1.8°) (2.8V) (1.68A) http://www.motioncontrolproducts.com/pdfs/nema17-stepper-motor-42mm.pdf
Z axis: M57STH51-3008DC-S (NEMA 23) (1.8°) (2.2V) (3.0A) NEMA 23 (57mm) Stepper Motors - UK Stock | Motion Control Products
Extruders: Same as X and Y…
I was wondering if I could use the stock power supply unit to power everything besides the heated bed, but I may order another Mean Well for the electronics side of the machine. I think the Replicape only supplies the heatbed output with 12V, not to mention that the board is protected by a 20 amp fuse. I’m going to look into using a relay for the 24V PSU to the heatbed. Please add suggestions if you have any.
Per CollectorCNC’s advice, I’m switching to a Bowden drive and a single E3D hotend. I may add a second hotend later on.
I’m still curious about the stock limit switches on the Cubex. They are nicely integrated. 3DSystems actually did a great job on the build of the Cubex… it’s too bad they did such a poor job with the software and filament system.
I have a few pictures, but last time I tried to post them, they never came through for some reason. I’m going to see if I can edit/add them to this post after submit it.
Thanks Guys!
I’ve been working on my extruder setup and I’ve ordered an E3D Chimera hot end… also still waiting for Replicape board, Beaglebone, and Manga Screen to arrive.
I’m putting the cart before the horse slightly on this idea, but one thing I hate about my Cubex is when there’s a filament error, instead of pausing the print, it just automatically fails the print. Why isn’t it possible to have the system “pause” the print and move your tip to the home or a designated position? I’m still very new to 3D printing, so maybe this just only happens with a printer stuck in 2013.I disassembled the extruder/hot end assembly that came with the Cubex, and the extruder itself is equipped with dual optical sensors and another sensor that wraps around the filament itself. It seems like the hardware is definitely capable.
