Hubsy
Hi Guys,
heated bed shows 120deg on display.
maximum temperature achieved 88 deg, measured with maplin laser gun.
Suspect thermocouple, how easy is it to replace?
And which one to use?
Thanks
Dave
Temperature on the surface also depends heavily on the thickness of the prinbed. I do have a lot of delta in the temperature too with my printbed because I got a very thick aluminium plate on top of the heated bed to straighten it out and on top of that there is glas with pei for a perfectly level finish.
Hi, the thermistor on my CTC also didn’t heat up enough, was causing issues with ABS and Sitall glass, so I replaced it, details here Coding Chase: CTC-3D and Sitall Hope this helps - also, on a later post I used an infrared monitor to read the temperatures, should help too. EDIT: just to confirm that in my case, replacing the sensor did the trick, upgrading the firmware was a good plus as well.
Suggy
Don’t rely on the mapin in thing, I have 1 and when tested against a know tempriture was way out
Hubsy
checked maplin unit against a commercial engineers meter. near enough the same.
Thanks for blog link.
Suggy
6
You will need to change the thermosister for a 100 thermosister Like these on the bay, item number 191885437601 That should fix your problem. The more layers you have on top of the bed the more you will need to increase the bed temp to get a proper surface temp
