Suggy
Hi, im trying to print using the right extruder for the main build and the left for the supports but it only uses the right.
Using Design sparks for the desing and simpify3d for the splicing. Both extruders are present in the extruder box. Primary extruder is set to right in the layer box, infill is set to the right in the infill box, support is set to the left in the support box, both extruders are set to 220 and bed to 27 in the temp box,
Hade to remove the letters and numbers as it wont upload due to it being flagged as spam
this is my start G-Code
enable build progress
; home XY maximum
home Z minimum
set Z to -5
move Z to 0
home Z slowly
recall home offsets
load right extruder offsets
move to wait position off table
lower stepper Vrefs while heating
S[fan_speed_pwm]
S[bed0_temperature] T0
S[extruder0_temperature] T0
S[extruder1_temperature] T1
T0 ; stabilize bed temperature
T0 ; stabilize right extruder temperature
T1 ; stabilize left extruder temperature
default stepper Vrefs
zero extruders
position nozzle
purge nozzle
slow wipe
lift
zero extruders
(notify GPX body has started)
this is my end G-Code
end build progress
send Z axis to bottom of machine
cool down HBP
cool down right extruder
cool down left extruder
stop blower fan
home XY maximum
disable stepper
play Ta-Da song
Can someone have a look and see if the settings are correct?
Thanks for looking
Ian
Suggy
Does anyone else have/had this problem and know how to fix it?
