The main CPU looks like an atmel 2560. Basically a RAMPS setup. If you want help over Skype and phone let me know. I sell tech support for open source Printers. $15 an hr but send me email directly or donation to my YouTube channel and I will help you out with your problem. Arduino 1.0.1 Open tools tab and select your comport, set programer to Arduino as ISP, and set board to mega or mega adk. Then try again. You will have to set the correct board in the firmware. george@georges3dprinters. com
Sounds like you might not have the driver installed. Check device manager for something like arduino or USB to serial device or something Good luck
Thanks, George. I reset everything and uninstalled RH, and reinstalled Arduino 1.0.6. The firmware seemed to update fine, but my LCD is still just a bunch of blocks. Repetier Host is recognizing the printer, however. Unfortunately, nothing appears functional. Could be a wiring issue. I will keep at it.
I had that thought, but I tried installing the driver that came with Arduino several times. COM3 appears when I connect the driver, though the name of the printer is never stated. Just says COM3.
You could try swapping the LCD connectors. Did you uncomment the right LCD in configuration.h?
Delete the two slashes in front of the line for reprap smart controller. In configuration.h
1.0.1-1.0.4 is usually recommend. Reason why is that library changed for LCD
Doh! You nailed it. I found it in the firmware. Thanks!!
And if you see me on YouTube, look up MK8 autolevel on Google, should pop up, then you can see what I have done. Firmware, Slic3r settings I share on my blog, georgeroblesjr.wordpress.com Well, that’s it for the night. Back to my pi Zero with octoprint.
anyone have a copy of the config file for the kossel delta rev b? everyone i try wont drive my printer. all the pretty lights are on but no motor movement. i am running RH I have updated firmware 10 times just wont run. it connects ok or says it does but no luck getting anything to move. cant even start my tunning. thanks
