I am a school student, and i need to make a Quadcopter. I have found a suitable frame for it, and I found it quite expensive to print with a shop. Can Anyone who has a printer, print this for me on a little budget (including only the printing cost and shipping) (I don’t have a printer) the file is in thingiverse, pls check the file, find the cost and inform me…
thanks…
link: one from this, FireFlo v2 by SirQuentin - Thingiverse , and four form this, FireFlo v2 Motormounts by SirQuentin - Thingiverse
Hey @Techpages,
If you go over to Online 3D Printing Service | Instant 3D Printing Quotes | Hubs page you can insert those files and see what the approximate prices are
where are you located? I can give you a deal on the shipping!!!
SOC3D
What’s your zip code?
Build time: 1 hour 7 minutes
Filament length: 3165.3 mm
Plastic weight: 9.52 g (0.02 lb)
Material cost: 0.24
Do a search for Klacam hub and I can do it in SLS using tough yet flexible Nylon.
$160 for all 5 pcs you just pay the shipping.
Hey depending on were you are located I can have all 5 of the needed prints done and shipped by Sunday morning for around $30-40. If you are interested please contact me for further information.
Is it true for all 5 parts on the same size as in the file? And what is the material cost, usd $? And I am in Sri Lanka , postal code KT 12404, and what’s the final cost for you excluding shipping?
SOC3D
8
I just downloaded the files and plated them using default print settings in PLA. Cost shows as $0.24 USD. Those parts are quite tiny and should be printed at a bit better resolution and fill than defaults which wouldn’t change to much. You should try to find a hub on or near your continent though.
