I printed a file so you can see if your printer is properly calibrated
As you can see, it does not become beautiful
I ABS typically used
If I print something small (1 x 1 cm) with 1 mm wall thickness it goes well (bottom photo)
But how well you calibrate the printer so you can improve?
In other words. How do you calibrate a printer ???
Ik heb een bestand geprint zodat je kunt zien of je printer goed is gekalibreerd
Zoals je kunt zien is het dus niet mooi geworden
Ik heb ABS gebuikt
Als ik iets kleins print (1 x 1 cm) met wanddikte 1 mm dan gaat het wel goed (onderste foto)
Maar hoe moet je nou de printer kaliberen zodat het je kunt verbeteren?
Met andere woorden. Hoe kalibreer je een printer???
MB3D
Your test model is too small for the printer’s nozzles and layer height. Try to scale it up by a factor of 2 in each direction, this will give better results on how overhangs (on the right side) or detailed engravings (the star and the wavy cavity) will turn out. Otherwise you can look around youtube and other forums for printer calibration guides.
Marius Breuer
Hard to print in ABS on the micro. If something warps or of it gets lose from the bed its gona fuck everything up. Try the testprint in PLA instead.
If you need to calibrate m3d auto calibrates… there is a function in settings for calibration.
