hi guys,
since about a week my zortrax m200 leaves some brown or black stains or spots in my prints, so i cleaned the nozzle with acetone bathing and cleaned/polished the nozzle in and outside, but the issue still persisted, so I changed the nozzle for a new picked up a fresh roll of filament ,cleaned the extruder , recaliprated the bed but no success.
i only use zabs
so may someone can help?
Hi There I find giving the nozzle a quick clean with a blade and just prior to print you will sometimes see the nozzle oozes about 10mm of filament that sometimes curls up and attaches itself to the nozzle. This then proceeds to burn and then transfers to your print. If you can, using long tweezers quickly remove the excess filament and your problem should go away. Alternatively are you limiting your fans? not cooling the abs sufficiently will produce unwanted burning sometimes.
I have this same issue, but it’s more visible on z-abs in sky blue and white color. As @trimethius said clean nozzle just before printing, taking excessive filament that is on nozzle.You can’t completely avoid this.
3DPP
Many Users have the described Problem, i too. But i have solve the Problem with using the zt-he hotend of z-temp
hello David
the problem may be the defective filament or the thermal shock that burns the filament .
sorry for my English.
Hi only hotend or the full kit? Because im not willing to invest another 250 bucks in a 2k machine called plug’n’print if this is a known serious issue zortrax has to fix this or i send them back the printer.
greetings david
UNREAL
7
Hi, like trimenthius said, you probably have some burned filament inside your hotend. Make sure your fans are working properly, you can also try rotate your model in Z-Suite to avoid burned spots.
I clean the nozzle before after and pause clean the nozzle on longer prints
Rotate the model doesn’t help much and i also cleaned the nozzle and hotend also inside
UNREAL
10
What’s about fans? Are they working properly?
Can you confirm that you are removing the oozed approximate 10mm length of filament 1 or 2 seconds prior to print?
From turning the machine on just getting the machine up to temperature will cause the nozzle to ooze. and if you calibrate prior to printing (I calibrate every time as a matter of process control) as expensive as this machine may seem from a hobbyists perspective, it is still deemed a cheap machine. I still think from an engineers perspective this machine is incredible. I researched machines for six months before buying and have not looked back with regret.
Yes i clean the nozzle just a sec before it starts the print before the autocalibration starts.
i also be happy with the machine this issue is new never had this before.
Do you have burning problems with all abs? or just one particular ABS Colour/reel of filament?
just to emphasise the exact part of the process you must remove is before print as the hotend must heat up again after calibration and it is this exact point of the process that the ooze is at its largest (from my observations)
One thing that you could try is making sure the thermocouple is indeed secured correctly or indeed measuring the correct temperature. I have built a relationship with my machine over the months I have owned it. the more I know about the machine the better the prints become.
If anyone has some pointers on zit reduction on nozzle strike I would love to hear it. (only happens on multiple parts)
Tomy
14
I scrape off the nozzle before every print… Very often the black,melted remains on the nozzle aré the causes for this…
Only zabs i only use this in sky blue white yellow and green is affected.
Just print everything in black and you’ll be fine.
3DMuse
17
I find that printing with white Z-ABS always require a certain amount of babysitting.
1.) Check the print every once in a while to make sure there is no carbon build up outside the nozzle.
2.) If the nozzle seems black on the tip, push the knob down until the print pauses (takes a few seconds)
3.) Use tweezers to pull off the string from the part where the nozzle paused. Be cautious not to shift the print around.
3.) Wipe the nozzle gently with some aluminum foil (gently!) until it is clean
4.) Resume the print.
Edit: I think this applies to any light colored filament. The nozzle needs wiping every once in a while. I wipe mine before and after every print, sometimes during prints if the nozzle gets black. There is a high risk that the black carbon “scab” will fall off and embed itself in your print.
3DPP
18
Dear David,
sorry for the late reply.
You need only the ZT-He Hotend.
for removing the goop on the outside of the nozzle I find using a small wire brush works very nicely. Just make sure you don’t rip up any Kapton or other high temp tape that maybe insulating your heat block. That said cleaning before the start of a print really helps prevent that stuff from building up. If you notice excessive buildup you can also try pausing the print and wiping the nozzle off (VERY CAREFULLY) with a *COTTON* (no synthetics here!) rag. Just be careful since the nozzle is obviously VERY hot and will burn you!
you could try raising the temp of the nozzle(by 5°c step till burns stops), by getting hotter the filament gets more fluid, and that prevent it to attach and burn…it sounds odd for a burned spots to rais temp, but it works…conter-intuitively ))
