Cobra
Hello all, I am having a problem with the build plate.Upon initial startup of my ctc 3d printer the build plate shows a temperature of 138 degrees celsius, but the plate does not heat up.The connector is showing some burning on the first two plugs. I took an ohm reading to make sure the hold down bolts are not shorting out the plate. I did notice that the power and heat plugs are shorting out. Is this normal for those two plugs ( first two plug pins ). Thank you all for any advise or help!!
Hello Cobra,
can you upload some photos?
I have not heard it before
Cobra
Hopefully the pictures will illustrate what is going on and that you might be able to advise. Thanks for the help.
Is this a heated build plate issue or is it the mother board?
