Hello everyone,
today i tryed to print PLA with my Bowden Extruder but it get stucken between the Teeth after Seconds…
I already changed from the normal Gear like This:
http://e3d-online.com/Mechanical/Hobb-Goblin-5mm
http://e3d-online.com/Mechanical/Hobb-Goblin-8mm
now i got this:
https://www.geras-it.de/documents/image/20/205/205.jpg
and it works for PETG realy well but not for PLA… same issue.
Got someone a Idea how to fix that?
Garyg
With the facts you’ve provided, I can only guess.
So here goes
1 - Can you push your filament through the hot extruder by hand?
2 - Does your filament fit into your Bowden tube?
3 - Do you have good tightness between your pressure roller and the Hobb-Goblin teeth?
Sometimes PLA gets pretty stiff as the roll of filament gets smaller.
That stiffness can cause exactly the trouble you are speaking of.
Try a new spool of PLA or warm the PLA up to about 30 degrees C
To get better suggestions, I would say following information would help others to be able to help you.
Type or model of printer?
Slicing software?
Photo’s of your setup?
Just some thoughts
