I have the flashforge creator pro. No matter how I try and level the bed left back is ALWAYS lower. Must be a warped bed to begin with. Any solutions for this? Thanks
Convert to a glass bed if it’s warped. Heck, convert anyway, it’s 100 times better.
Check the bed stop sensor, normaly the screw loose.
cobnut
Hi @jimdigs when you’re levelling the FF Pro it’s important to turn all the screws a little, regardless of which one you’re actually levelling. For example, if you’re loosening (bringing the bed closer) the front one, for every full turn of that screw, loosen both the back ones a half-turn or so. When you move to the back right, leave the front one alone, but loosen the back left one half-turn every turn of the back right. Then do the back left on its own.
You should find this will allow proper levelling. You may have to tweak it a little, but it works for me.
I put a straight edge on the bed and it is lower on one side. I can slide a piece of paper under it on that side. I have a glass bed and it sits on the bed so it doesn’t help there.
I have done this but the bed is warped. I put a straight edge on it and I can slide a piece of paper under the one side. Tang said they will ship me a new bed since I have only had this printer two weeks.
But the glass shouldn’t flex so much as to follow the contour of the warped bed. It would even it out, unless your glass is really thin. I use a 5mm (or so) thickness and its perfectly flat compared to the not so perfectly flat aluminum bed.
All I know is that with and without the glass there is a low spot in the left rear corner.
