when I try to print, my bed drops 15mm then starts printing (air printing). Is it from how my marlin is set up? I’m using a Davinci AIO with a ramps 1.4 and Repetier Host.
First of all, I want to say that I had a Davinci 1.0 Pro.
That printer was a nightmare for me, and I would not recommend anything from Davinci, as they have awful customer service, and can never help you with anything.
I believe your issue is in the print settings. I would recommend using software such as Cura, ReplicatorG, or Slic3r for your prints (unless using SD).
Hopefully this helps,
Carter
What I’ve been doing is start the print, hit pause, home Z and then print. It only does the 15mm drop at the very beginning of the process. It wasn’t doing until I did a Marlin upload. I’m thinking it’s something in there, I just don’t know where
