luc358
hello everyone,
I’m having problems with my 3Dprinter (Anet A8) not detecting my inductive endstop ( IG511A ) I
made a voltage stepdown circuit using a 20kΩ and a 28KΩ resistor (I measure 4.75VDC on the signal cable) the software I am running is Skynet 1.1 Alpha
i dont know what i did wrong, if i jump the cable and use M119 it does trigger
here are my settings / datasheet of the sensor / images
http://www.dropbox.com/sh/fv4nw1cbn7pe38l/AAC0Bmzp_03WlmORE3WkITIza?dl=0
if you need more information you can ask
Thank you very much
