Dear All,
I am a new user at 3d Hubs, and I have just uploaded 2 files I have urgency to print.
They are very simple ones but the quantities are big and the deadline is a bit tight.
- 600 units of Hex8
- 1200 units of Hex4
color: white
material: ABS
deadline: 29th august
I was sending direct requests but I can only do 5 a day, which makes it a bit stiff to me. I need to have as many quotes as possible so I can make it happen.
Thank you so much for your kind attention,
warm regards,
I hope the link to my files work:
https://www.3dhubs.com/3dprint
https://www.3dhubs.com/users/umasudo
MB3D
What’s your budget for one Hex4 and one Hex8? I think you need to order at multiple hubs at once to get this done, however I think that would raise the cost by quite a bit, compared to ordering at one hub only. I bet @Gabriela3d and @Arnoldas can recommend some local hubs for this purpose. I’m currently not able to open stl files (I’m on my mobile device) so to give you a proper estimation and more precise recommendations I’d need to know the size and volume of both models. Cheers, Marius Breuer
Dear Marius,
Thank you so much for your kind reply. Here are the specifications:
hex4.obj (4.7 x 0.5 x 3.3 cm),
hex8.obj (8.6 x 0.4 x 4.1 cm)
- 600 units of Hex8
color: white
best, Patricia
Left
Hi Patricia,
You may want to contact 3D hubs Antwerp community mayor @Michiel.
He will probably have some connections in our area to get this done.
Luuk
@Benson Laurent might be able to help you out with his dual extruder printer.
Thank you so much! I’ll contact them!
I can help but only in PLA …
I can print on my 3 Ultimaker’s!
You can contact me on my Hub if you like!
greggg
10
Bonjour,
Vous êtes d’où ?
Pouvez vous m’envoyer vos fichiers par mail ?
Cordialement,
Greg
zippi
11
@umasudo
I can print with my Ultimaker 2 but i only got white PLA if that is okay
You can send me the files and I can tell you how fast I can print them and the price.
Best regards
Alex
Jim_12
12
I’m a hub from Brussels and I certainly can help printing them.
At the moment I have Natural ABS and white PLA but I think there is still time to order white ABS I think.
check my Hub too see the print quality if you want!
I can help too with 4 ultimaker 2s… send me an order through my hub please…
I’m in Utrecht BTW so that should be fairly close to Brussels…
Hey Patricia,
I’m in London. Can print off some of your items if needed. Can’t see your files though. Please click the paperclip and upload the files.
AndyL
Pot8oSH3D <---------------- Click here
Jim_12
16
I think Patricia allready found a solution… There hasn’t been any activity since yesterday and I haven’t heard anything.
umasudo
17
Hey Jim and everybody,
Thank you very much for all the help and sorry for my late replies. I have found a solution, thank you very much for all the help!!! Patrícia
Left
18
Hi @umasudo,
Can you share your solution with us? It maybe can help some other people.
Also, I a bit curious.
Jim_12
19
Glad to hear you found a solution!
That’s the power of 3DHubs wich solves your problems in no time!
I’d help if I wasn’t so far away from Belgium. I’m an ocean away, so i won’t be much help time-wise
