Hi guys,
Recently I ordered the anycubic kossel linear from amazon and after I got it assembled I started calibration. I leveled the center point, then I leveled the 3 outside points they tell you to level. When I homed Z though, the nozzle was 3mm or so away from the build plate. Does anyone know how to fix this?
Thanks in advance,
Benjamin
Have to adjust on firmware
You can also lower the end stops
Adjust Delta smooth diagonal rods, or Delta radius
