Polymer adhesive designed for fixation of the print during 3D-printing. Suitable for tabletop 3D-printers, can be used on a hot or cold.
PROGLU3D PLA-Cold this is not another series of modifications of hairsprays or stick glue , which are flammable and are not biodegradable.
https://youtu.be/6Lw9rVHglIo
The product is designed for all materials derived PLA Filament and Flexi (Ninjaflex, Flexi-PLA etc.)
Polymer adhesive designed for fixation of the print during 3D-printing. Suitable for tabletop 3D-printers. The glue ensures good fixation, avoids warping and deformation, and can be used on a hot or cold printing table (minimum 20°C)
ProGlu3D can be used up to 10 times or more and is cleaned easily afterwards with water.
ProGlu3D is eco-friendly, water based, non-toxic and solvent free.
User manual: Shake bottle before use. Spray gently a thin layer on ProGlu 3D on the printing table. Ensure that a uniform film is formed. Start printing when the film is completely dry. For printers with a heated printing table, set the temperature at 40/60°C to accelerate the drying process, start printing when the film is completely dry.
Optimum temperature of heated table is from 20 to 120°C.
3D-printed piece is easily removed when the printing table is cold.
PROGLU3D-ABS Platform
Eco-friendly polymer based glue
Suitable for print in ABS Plate
Stable 3D-printing hot plate
Excellent fixation of 3D-print
Easy to use – easy to clean
Several times use.
Glue PROGLU3D-ABS Platform is designed for application on platforms ABS Stratasys 3D printers - Mojo, uPrint SE,
Dimension 1200es/Elite, Fortus 250 MC
The adhesive provides excellent adhesion built elements, and micro film provides protection from attachment to the RAF print directly to the platform. Built Usov elements with a spatula and suitable platform for the next use. Damaged adhesive film usuówamy using the product PROCLEAN3D and apply a new layer of glue PROGLU3D ABS-Platform.
Purpose: Polymer adhesive designed for fixation of the print during 3D-printing. Suitable for Stratasys Fortus 3D-printers and the other with equipped a ABS printing plate. Using glue prevents wear of disposable plates to build a 3D model. The glue ensures good fixation, avoids warping and deformation, and can be used on a hot printing table (minimum 70°C) ProGlu 3D can be used up to 5 or more times and is cleaned easily afterwards with PROCLEAN3D. ProGlu3D is eco-friendly, water based, non-toxic and solvent free.
Cleaning the regular Glue can get so messy! Curious about this :wink:
Here are some photos from the use of glue PROGLU3D PLA-Cold and PROGLU3D ABS-Platform
https://plus.google.com/u/0/103560243951567752460/posts
