I have a JPEG and an Obj of myself.
I want to print it with full color but am having trouble adding the JPEG onto the OBJ.
Does anyone know what program to use and if so, what tool to use.
If anyone knows a youtube tutorial that would be great.
Thanks,
Eugene
I have something you can try. I have never printed in full color so it may not work.
1.Select your surface
2.Properties (Tab on the right side of your screen)
3.Under “Properties” directly below the tabs you should see a small paint tube, “Materials”
4.Under the “Textures” select “color”, right click where it says “(empty - click to assign)”
5. A screen titled “Types” should come up and you should see a folder, when you hoover your courser over the logo it should say “Load from fle…”, right click that.
6.Select the image you want to import and load.
7.You need to be in the rendered view
If this is not what you were looking for I will continue to play just let me know.
