I have a monoprice select mini that won’t feed ABS filament. I’ve tried various temperatures. The filament will extrude in manually pushed through. Any advice?
Not really familiar with the printer but maybe the drive is not gripping the filament enough? Is the filament gouged or ground from not feeding when you pull it back out?
Worked it out thanks. Problem was broken piece that pushes the filament against feeder. Used a clamp to hold it while printing a replacement part
