Here some of the specs of our Premium Filament:
ABS filament 1.75mm/spool printer temperature: 210-250 ℃
ABS (Acrylonitrile butadiene styrene) is an oil based filament and has a higher melting point than PLA. ABS filament is commonly used in 3D printing. It has the following characteristics:
  1. Softer than PLA, but high strength, good toughness
  2. Density is small, when printing larger volume model lighter, save money
  3. Cost-effective, can be processed in wide range temperature
  4. Accurate diameter: 3.0/1.75mm, variations + /-0.1mm, roundness +/-0.05mm
