how much would it cost to 3D print a plant pot of 17X12X7 (LXWXH)?
Need a 3-d model do give a bid.
Ed
Hi @ranamukha, the easiest way to find this out is to upload your file at Online 3D Printing Service | Instant 3D Printing Quotes | Hubs. This will result in a list of Hubs in your area that can help with your print. Hope this helps!
pnanna
Much to consider here…Besides height width and depth, there is also thickness and material type. As a pot will it need to be water tight for the species of plant? Are there any decorative features like a logo or extruded artwork? There’s a lot you can do.
Enza3D
Hey @ranamukha
Are those dimensions in inches? Or are they in cm? If they’re in inches, you’re going to need to find a very large printer!
As @pnanna said, the price depends on a lot of other factors than just the size, so it’s really hard to give a quote without knowing some specifics of what you want.
Left
6
It would cost 58.15 without shipping at my hub.
If you order 50 - 100 pieces. I make it 50 each
pot17-12-7.stl (1.45 KB)
If you had a model of the file and what the planned use is that would help determine the correct material needed and approximate cost.
Do you have a model? or need help with making a model also?
SOC3D
8
@ranamukha using the stl @Left posted I can run this using a single line of 800 micron x 480 micron plastic (.8mm x .48mm) for around $8 + startup costs.
https://puu.sh/qgvhT/5088801c9b.png
These prints are generally watertite though a coat of waterproofing spray doesn’t hurt especially on the bottom.
