I would like some information, or some input, on an idea I have for a part for work.
I want to 3D print a larger tapered, hollow cylinder in FDM so I can get it coated in metal. Something about 700mm Base O.D., 675mm Tip O.D., and 1300mm in height. I am thinking 8mm thickness, and then 2 or 3mm thick metal coating after. I also need it to withstand about 130 C for up to an hour without warping.
Printing in pieces and joining after is not a problem, as long as the out surface is relatively smooth after joining.
Suggestions? Is this doable?
Thanks in advance.
Most larger printers max out at around 250mm in any direction. Printing something that large would be costly. Maybe 3d printing isnt the best method.
Have you thought of making a frame out of wood and wrapping it with a metal skin instead. Or some other method
Thanks for you reply.
We are also working on other methods. This was just another I had.
