Hello I would like to print a cover for my portfolio in Barcelona. Preferably in some sort of rubber so that it can bend and open. However I do not know how to use special program to create a design file. How can I asdk someone experienced for help to design it for/with me and print it in Barcelona within 10 days?
Hi Justyna,
Here is a list of Hub near Barcelona that can help you with your project :
You can contact them to talk about your project !
Good luck
Hi Justyna
we are available for study your proposal, you can contact with us in maker@conventagusti.com
https://www.3dhubs.com/barcelona/hubs/makerconvent
oscar
Hello, there are different ways to do this. The most important to decide the way is the design. If the cover will be flat with an engraved design, maybe you could use different technique like laser, to engrave directly to a rubber part. If the design contains some 3d design with engraved parts, etc, then you could use 3d printing or silicone moulding if you need quantity. All the techniques are not very expensive. If you need more help let me know and we’ll see the best way to produce your idea.
