I have printed gears in high detail resin, they were poor at best. What material would give me a better result? SLS or maybe carbon fiber reinforced nylon?
What’s the speed and load? what type of gears? what size? too many blanks to get the right answer
Speed is about 2500 rpm, it is spinning a turbine, dual and large gears, i would say about 4x8inch
Depending on the detail required, SLS Nylon might be good, otherwise you could use an FDM Nylon printer. Worst case you could even use laser-sintered metal.
Hope this helps,
Martin
Garyg
2500 rpm is very fast.
I would be concerned with heat generated while spinning against another gear.
I’ve only build chain drive gearcases.
I always use metal gears until the reduction is less than about 300 rpm.
Remember, you are working on thermoplastics that will melt if the temperature gets too high.
just a thought
