Hi… I have a 3d file and when I uploaded it it says the model may be to big (7810 ✕ 7810 ✕ 4647.3 cm (Modeled using cm)) can it not be scaled to a smaller size when printing? 3D Hubs does not show me any printers in my area or anywhere in world now…I would like to get it scaled down to approx 36 x 36 x 23 … is possible? thanks… Len
SOC3D
You should be able to put in an inquiry at the hub of your choice without uploading a model. Just click the contact hub button and let them know you need the model scaled. Any reason you cannot scale it via software before exporting it?
At 36cm x 36cm x 23cm That piece will need to be broken up in to several pieces for most hubs to be able to print it as well.
I run a hub in Winnipeg, I can take a look for you if you like.
Hi. Sure… would be nice to talk to someone in Wpg about this… also I am flexible when it comes to size… this is basically an experiment to see how it will look printed in 3d… the model might have a few bugs in it still… how could I send it to you? thanks… Len
Send it to my email. Banmanj@gmail.com
