Don’t use colours that square measure a hundred black or white. so as to point out that associate object has volume, you would like to possess square measureas that are highlighted and shaded victimization mid-tones for distinction. If you have got a virtual material that’s whole black, your model can look flat as a result of the variations between the shaded location and therefore the midtones won’t be visible. Same with a completely white model, except that during this case, it’s the variations between the mid-tones and light-weight areas that don’t seem to be visible.
This is good advice but you should give a little more of a intro/overview of the subject. This is an interesting topic but a lot of people might not get what you are talking about.
-Jesse
