The first problem is that i cannot seem to get onto the zortrax website at all anymore, i always had a problem with the support part but now i cant access it at all.
The second problem is that i cannot find any help anywhere oh how to change the v1 hotend to the v2 hotend as i would like to but i dont want to risk breaking anything.
Any help would be greatly appreciated.
http://support.zortrax.com/
To change your hotend:
-Take out the filament
-Loosen the 2 hex screws for the heater and thermocoupler
-Loosen the 2 hex screws in front of the extruder/hotend
-Pull out the hotend en put the new one in. Be sure to push it all the way up and tighten the screws gently.
Hope this helps.
Two things:
1) I was able to access there website with no problem. It may be worth checking http://www.isitdownrightnow.com to see if it’s your computer/browser having an issue or what.
2) I downloaded the maintenance document you need to replace the hotend for both versions.
Enjoy!
hotend-replacement.pdf (1020 KB)
Our site is up and running.
Bear in mind that Hotend v2 doesn’t have same signal cable as Hotend V1, so dont be confused looking at pictures.
