@wirlybird yeah, the “nut job” file you download is an OpenScad file, so you need to open it in Openscad, then adjust the settings in the text file on the left of the screen. Looks complex, but for most things you only need to change whether you’re building a nut, thread or bolt (the “type” setting, around line 28), then a couple of numbers. You only need to edit the bits of the file that are relevant to what you’re building, so if you set the type to nut, you only need to edit the figures under the “nut” section.
I use it all the time; I make “proper” nuts and bolts but also use it to generate rods and nuts that I merge into models.
Cool, I’ll look at it this holiday, I seem to have a very long weekend coming up! Working on getting Slic3r running on the FFCP and messing with the MK2.
:(( Still waiting on my Mk2… Tried Slic3r and just got horribly lost… What benefits does it have over Simplify?
Have you talked to them to get an idea of when? I talked to them a bunch and politely pushed to get it going!! they are really helpful but remember the time difference. When I was talking to them (via chat) it was the middle of the night there so they had limited access to info.
Slic3r is intimidating. Prusa packages a custom version of slicer for use with the MK2 and it does some nice prints. I have had pretty good luck with S3D also. They have a FFF file for it but their emphasis is on Slic3r.
Slic3r is a bit of a pain if you want to connect via USB. You have to use an additional program, Pronterface. Kind of a pain. Export from Slic3r straight to SD card is pretty straight forward.
Slic3r is probably more powerful with much more fine control over the model printing but S3D would be the more glamorous solution.
I am getting Slic3r running with the FFCP to mainly learn it since I am very familiar with the FFCP. Finally got a test cube to print and the result was definitely acceptable.
@wirlybird interesting, I may need some private conversations with you once my Mk2 arrives… :slight_smile: Anyway, I guess we should stop hijacking this thread :slight_smile:
I just made another one of these and I think I am getting a similar pattern.
