M4rty
21
I think I found the solution. I was trying to figure out why the test prints work great, and the other prints didn’t. I noticed on videos how other Creator Pros might have a bit of a different extruder movement before it started printing. I checked the script for it in Simplify, and the only line was to home all axes! I got a couple different lines from the internet, and was finally able to print something out! I tried to keep it the same temperatures as the test prints do, but I had to slow down the extruder so the first layer wouldn’t bunch up. But this is all trial and error now.
I guess the only reason I am seeing this now is because before the Replicator G corrupted my eeprom, and after the reset I didn’t connect it back to my pc, I just printed straight from the SD!
That means you don’t have the default profile for the FlashForge Creator Pro. That page I linked had a much more interesting start gcode than merely home all axes:
- ; **** Replicator 1 dual start.gcode****
- M103 ; extruder off
- M73 P0 ; enable build progress
- M70 P2 (Simplify3D)
- G162 X Y F3000 ; home XY maximum
- G161 Z F1200 ; home Z minimum
- G92 Z-5 ; set Z to -5
- G1 Z0.0 ; move Z to 0
- G161 Z F100 ; home Z slowly
- M132 X Y Z A B ; load current position from EPROM
- M135 T1 ; load left extruder offsets
- G1 X70 Y-70 Z30 F9000 ; move to wait position off table
- G130 X20 Y20 Z20 A20 B20 ; lower stepper Vrefs while heating
- M70 P1 (priming nozzle…)
- M6 T0 ; wait for right extruder to warm up
- G130 X127 Y127 Z40 A127 B127 ; default stepper Vrefs
- G1 Z0.4 ; position nozzle
- M108 R5.0 ; set extruder speed
- M101 ; start extruder
- G4 P3500 ; purge nozzle
- G1 X65 Y-65 Z0.15 F1200 ; slow wipe
- M103 ; stop extruder
- G1 X60 Y-60 Z0.2 F1200 ; lift
- M73 P1 ;@body (notify GPX body has started)
- ; **** end of start.gcode ****
M4rty
23
Oh yeah she runs like a charm now! Thank You!
