@nagarajgaru said it all, except maybe one thing I’d like to add. You cannot translate 0% to 100% of infill to 0% to 100% of warping. (Not that you did that, exactly, @DaJay23D, but hold on, making my point here :slight_smile: ) I’d say that at 0%, only shells can wrap, and probably wont, because its only them against the 1st layer bonding. at 10%, depending on infill pattern, you’ll get a low/average solidity part that may cause few warping because again there is not much plastic to fight against the bonding. At 50% though, you have both lots of plastic willing to bend, and lots of empty shells allowing it. Now, from 50% to say 99%, I do not know exactly what we should expect, better or worse, but at 100% infill, if you look at @The_Build_Shop print, zero warping, I wonder if there is so much place left for warping? I mean, if the bounding to bed is good, and if the -say- first 10 layers dod not succeed in their strong will to warp up… Maybe then the think flat layer of plastic helps the rest to stay flat too? Not that I sudenly had some AM training, just wondering if it is thanks to either "Z-"ABS filament or Zortrax high quality printer “magic”, or if, indeed, 100% infill, while costly, can also be an option to fight it?
I did start with ABS on my first prints and I also thought I “tackled it” pretty well :wink:
About your opinion on PLA, I’d say that the downside of PLA is that you cannot find a nice RED :-)))
Other than that, printing PLA is so eeeeeasy! on my FF, I use borosilicate + 1 layer of dimafix, then 60°c all long. Never encountered any warping with that.
On my Prusa, on which i’m printing small parts most of the time, I just use glass + Garnier fructis airspray + no heating. Excellents results too.
BUT sometimes, you ask for PLA and you get sh*t! I even once ordered from Colorfabb, and it was lost during transport, then found, and man, can’t tell you where it stayed for a month but I could not do anything with it anymore…
just an idea, I use 90degrees celcius for the bed, for problem causing prints I use “ABS slurry”
Just add a little piece of ABS (3cm) into little amount of pure aceton (about 20ml) and let it dissolve for 5 min.
Then pour it to your pre heated print table and aceton will vaporize in a minute, leaving a thin but strong ABS layer.
Start printing on that, the results are worthy of the trouble
Empty wardrobe works great, I also store my filaments in the drawers in it, I can still use filaments opened more than a year ago, without any trouble.
Fit these to your FF to keep in more heat.
how is your filament coping with all the moisture being exhausted from the drier below, i had mine in the laundry and found my filament was turning shit
