I’ve been using FrogTape Painter’s Tape and ABS Glue to much success. Keep the board about 110C. How old is the filament you’re using? If it’s been out for awhile it could just have absorbed enough water (and become sentient enough) that it’s done with you and don’t have time for your printing shenanigans.
I had the same issue. Even went so far as changing the build plate covering (boy that was a mistake). I finally just started wiping the build plate down with alcohol before each build and for some reason that helps, a lot! I even have trouble getting some parts to come loose now. I print with extruder temp at 240C and bed at 110C with ABS and it is working well so far. I also have a FFCP.
The reason is fingerprints, the grease left by a single fingerprint is suffient to stop a print from sticking to the bed, wiping with alcohol removes all the fimger print grease.
Besides all the other tips regarding leveling, etc. be sure you have a flat surface face down. The way you tell us you use the sliders on the print preview screen to see what the first layers look like. I find that using a brim a few mm out helps because if your print isn’t level, the brim won’t encircle your print. Also slight curvatures will cause problems because s3d won’t create a 1 layer support structure. So look carefully at the first layer and watch as you add layers (single layer checkbox is good for this) to make sure each layer is fully supported by the layer below (except for small overhangs on the edge for 45+deg overhangs)
Hope that helps,
Lyle
You can try pausing your print after the first few layers and putting extra glue down. If you have tape down you could even try super glueing the first few layers down.
I use a regular glass bed with ABS Slurry. The key for me was how to apply the ABS Slurry. For me se solution is apply the slurry with a sprayer, this way the slurry is applie uniformly and the ABS stics verry well, no warping at all even y big prints.
It is essential to preheat the bed before printing!!
i would recommend bed temp 105 extruder 210 make sure that surface is clean if you used alcohol be careful some liquid they have some kind of lubricant for the human body so it cleans but it also leaves a residue of grease of slick surface you dont want that also used a new clean cloth never used with any liquid and it should work.
also i used this in the past and it work for me .
Okay, I’ll say it… for ABS use a raft. You have Simplfiy3D? Your prints will work every time and no glue, slurry, or magic juice is required. Plus, because you arent going to be scraping the hell out of the blue Buildplate, it will last ages (weve had ours on for literally months, with daily printing)
Without a raft, large pieces will warp and begin lifting. For PLA, its not needed.
I considered not using a raft, but then decided life was too short. For ABS, print with a raft and spend time doing other stuff.
hope that helps
:slight_smile:
It amazes me that everyone is still touting hair spray, ABS slurry, and glue sticks when you can eliminate all that hassle forever by simply putting a sheet of PEI on your glass bed. ABS and PLA stick with no effort on PEI and remove easily when the material cools. You can use less heat on your hot bed because the ABS sticks easily to PEI.
The only caveats to consider are 1, you have a level bed and 2, you be careful not to scratch the surface. A level bed is a must regardless, but often overlooked.
Bring your hot end so that a sheet of paper just slips under the hot end and the PEI when at zero with the bed heated to the temperature you will be printing. It is very important to level your bed when it is at the temperature you wish to print on!
If you try to squish the ABS into the bed like you have been used to with glass, you will find it much more difficult to remove! Use canned air to cool the part and it will pop right off if you are in a hurry.
Since I went to PEI as a bed surface, I have enjoyed 100% success rates with no mess, no fuss, no wasted time or material, and no need to use rafts or other crutches.
I use ABS exclusively on my Replicator 2X. I use Simplify 3D and the MakerBot software. I found that the actual surface temperature of the Heated Build Plate was about 10 deg C lower than the display on the 2X was indicating. I measured the surface temperature at multiple points of the bed over a half hour period using an infrared thermometer. I checked the temperature with the infra red unit exactly perpendicular and at various oblique angles, to ensure that reflectivity of the Kapton surface was not affecting the readings. I have a stainless steel replacement nozzle and run it at 238C indicated. I have not been able to get a repeatable temperature reading from the nozzle using the infra red thermometer I have.
Using Simplify3D I use 2 brims about 4mm from the part to be printed, I have used rafts only once and was totally unsatisfied with the bottom surface finish and the effort required to improve the finish apearance. I have not used them since and have no need for them. Properly set up they probably should not be necessary. They waste filament. They take longer to print. They cost in clean up time. You should work to eliminate the need for rafts. I feel they are a crutch for an improperly set machine.
I buy bulk rolls of Kapton from Asia. I wipe down with alcohol every couple of prints. You could use those white cotton gloves that are used to handle museum artifacts, if you want to keep fingerprints off the surface. I preheat the build plate and the nozzle for 10 to 15 minutes before the first print of the day and before restarting after the surface may have cooled down. I use the Makerbot supplied clear cover to keep the entire interior of the unit warm. I never use slurry, hairspray, painters tape, or any other surface treatment. I just use clean Kapton. Most times I have difficulty getting the prints off, not making them stick. I keep a wood dowel and a mallet to pop some of them off. Others I use a long, 25mm wide, wood chisel to get under the edge and pop them off. Getting prints off the build plate is my biggest problem.
As others have said a flat surface and correct gap are key. BEWARE. Test the tightness of the bushings of the print carriage before levelling the bed. Do this when the unit is cold. To do this, lower the build plate. Move the carriage to about the centre of the build space. Now try to lift the print carriage up by pressing up on the bronze bushings of the carriage. If you get movement, you will have to take extra care in levelling the bed.
My unit has movement. So to level the bed you want to avoid having the carriage be lifted while placing the measuring media under the nozzle. You could have too tight a nozzle clearance or too loose if the carriage is not down evenly on all the bushings of the print carriage. I now have linear bearings on order to see if that helps. The weight of the carriage should keep the carriage assembly down. If you are not careful you could be lifting the carriage with your bond paper or feeler gauge and have one corner high and another low, causing uneven adhesion.
Finally, if I see the first layer is not sticking or is too thin, I open the front door and make a slight turn on the bed adjusting screws to raise or lower the bed. In the worst case I will pause the print job, from the front panel, reload the filament, and resume the print job.
Summary. Clean Kapton bed. Raise bed temperature. Make sure bed is level. Keep build volume warm.
I have to reiterate what was said before on PEI.
You won’t worry about ABS sticking ever again when you add a thin sheet of PEI to a glass.
My problem with PEI is actually getting the prints off! Not had quite the same luck with PLA though, my PLA has trouble sticking to my PEI bed.
I have printed alot of ABS. I found that there are 2 different issues you can experience while printing.
First one mentioned in the question is keeping the ABS to stick on the buildplate.
Personally I used to use PET tape ( much stronger then Kapton and high temp resistant wich prevents it from crumbling like kapton does after a while combined with ABS juice) This works very well but after some tome I changed to using Buildtak (don’t mean to promote it but that 's what I use to avoid bad acetone fumes from ABS juice)
Second issue, prevent ABS from warping when the z height of your print increases.
For this it is best to have an enclosed chamber. As someone said before plexiglass doesn’t give the results I would want.
Keep the extruder temp as low as possible. This way the temp difference between extrusion temp and chamber temp is kept as low as possible. This way the filament can cool down less drastically.
The key is also to have the good distance between the head and the bed. Since I set the good gap between them I don’t have stick problem anymore. Also you have to set a 150/200% width for the first layer, if you have a 0.4mm nozzle it should print a good large and flat layer 0.6mm width for example if it’s look like a round line then you are too far from the bed!
I have a solution:
Use this special ABS sheet. It is like “buildtac” but much cheaper and if you treat it nicely you can get more uses out of the same sheet.
How it works is that there is a layer of weaker ABS on a PCB sheet. The printed ABS filament bonds well to it, yet separates easily since the sheet’s ABS bond is weaker.
If you sit down and add up all the money and time wasted using tapes, sprays, and glues, it makes a lot more sense just to use a low cost sheet that will give you reliable results.
Want to try it out: buy it from here:
1 sheet: http://www.ebay.com.au/itm/191793470523?ssPageName=STRK:MESELX:IT&\_trksid=p3984.m1555.l2649
4 sheets: http://www.ebay.com.au/itm/191793472041?ssPageName=STRK:MESELX:IT&\_trksid=p3984.m1555.l2649
or contact for larger orders, custom sized sheets, etc: InventionFactory@debeers-education.com
hi have you tried double sided kapton tape ? rick
Hi Rick, personally I have not, but I have used single sided and also experimented with double sided sticky tape. I found above 60 degrees Celsius the stickiness became too soft and the brim would lift off. Removing Kapton is a pain in the back side. This is what I really love about the ABS sheet. You can remove and add it quickly without any mess. Happy printing!
How long will this PEI tape last if it never gets scratched?
I have great results with 1/4 inch glass and hair spray, but if PEI can last a very long time; I may want to try it out!
I have a solution:
1 sheet: http://www.ebay.com.au/itm/191793470523?ssPageName=STRK:MESELX:IT&_trksi…
4 sheets: http://www.ebay.com.au/itm/191793472041?ssPageName=STRK:MESELX:IT&_trksi…
I have a solution:
Want to try it out: buy it from here: | eBay
Hello Brian,
At 3Bros3DPrints, we print with a metal bed and have found the best way to print ABS with minimal to no lifting is having a bed temp of 125C and a good first layer. Disable any fans as well as that is a big factor in prints lifting and layers not setting properly. Hope this helps,
3Bros3DPrints
