Source custom auto parts to accelerate innovation
Tight tolerances & complex geometries
Huge selection of durable & resistant materials
Get full IP protection and quality documentation
Automotive part manufacturing is faster with Hubs
Hubs helps you get on the road faster without compromising on design or quality. With our instant quoting platform and specialized supplier network, you can bolster your supply chains and get custom parts for every prototyping, R&D, validation and full-scale production need. Hit your targets faster and never miss innovation deadlines with Hubs’ cutting-edge capabilities and near-limitless capacity.
Hubs is ISO 9001 certified and our suppliers have industrial certifications.
• ISO 9001
• IATF16949
• ISO 13458
• ISO 14001
• ISO TS16949
Get validation reports to ensure the highest quality and compliance.
• CMM Inspection Report
• Full Dimensional Inspections
• Material Test Reports
• Material Certificates
• Certificates of Conformance
• First Article Inspections
We use a rigorous set of protocols and procedures to maintain quality.
• Special tooling
• Sample size inspection
• Dimensional checks with calibrated equipment
• Review of all quality documentation and industry certifications
• Full IP protections on the platform and within the network
Local sourcing accelerates the automotive manufacturing process
We can now offer local sourcing for CNC machining in the EU and US. We’ve expanded our local networks to provide custom parts faster within your custom clearance zones. With Hubs Local, our manufacturing partners send parts directly to you, which means fewer logistical hurdles and faster delivery times.
Read more about local sourcing
Rapid manufacturing for automotive prototypes
Prototyping is a crucial step in developing automotive technology, and definitely not when you want to be waiting around for parts. Whether you need a few complex parts or several thousand, our platform and project teams can quote rapidly and deliver components in days. We can also scale from prototyping to small batch production quickly and deliver parts to stand in for First Off Tools (FOTs) while you’re still looking for a serial supplier.
How automotive companies use Hubs
Automotive manufacturing capabilities
Milling, turning and post-processing
Tolerances down to ±.0008 in (0.020 mm)
Lead times from 5 business days
±0.5% dimensional accuracy with a lower limit down to ±0.59 in (0.15 mm)
Lead times from 1 business day
Tolerances down to ±.004 in (0.010 mm)
Wide range of part complexities and sizes
1 to 1M parts
Why the automotive industry chooses Hubs
Designing destination EV chargers of the future
Find out how we helped LEKTRI.CO to accelerate its development cycle and scale the business with injection molding services, fast lead times, smart pricing and expert DFM support.
Materials & surface finishes for automotive parts
We give you access to a huge range of materials and surface finishes for every application through our global network of specialized manufacturing partners.
Select from a broad range of industrial-grade materials
Steel, mild steel & stainless steel:
304/304L,
316/316L,
430,
301,
4140,
4340,
Tool Steels
Titanium:
1,
2,
5
Aluminum:
6061-T6,
6063,
5052,
5083-H111,
2017,
7075-T651
Thermoplastics:
Polyethylene (PE),
Polypropylene(PP),
Polycarbonate (PC),
Commodity polymers:
Polyethylene terephthalate (PET),
Polyvinyl chloride (PVC)
Select from these finishes to protect your parts
Anodizing
Powder coating
Electroless nickel plating
Insert installation
Heat treatment
Passivization
Gallery of automotive parts
How Hubs helps automotive companies innovate
Our manufacturing partners can achieve incredible geometric complexity. No matter how complex your design is, we have the capabilities to produce whatever you throw at us with exceptional mechanical and cosmetic properties. Our network is equipped with the latest 3D printing and CNC technologies, including 5-axis machines and industrial SLS and MJF printers, to produce rapid prototypes and small batches of production parts with ease.
Time is almost never on your side when you need to innovate quickly and get your projects off the factory floor and onto the road. Instead of waiting weeks for quotes, use our platform for instant pricing and advanced DFM analysis. Compare quotes easily and get your parts into production faster so you’re never late for the automotive revolution. Whether you need to make tooling equipment for testing, need a single part to release a fleet of vehicles, or update your technologies to meet the electrification age of automotive, Hubs is your comprehensive solution.
Our automotive engineers and seasoned mechanics are ready to help you create innovative products and keep you on track. Project teams at Hubs work alongside our instant quoting and DFM tools to build plans customized to your production needs. We know how to save your shop time and effort, and how parts are used across every facet of the automotive industry. We’ve been in the shop ourselves, and understand that even the smallest thing can cause big delays. At Hubs, our mission is to get you from prototyping to your customer’s driveway as seamlessly as possible.
FAQ's
How do we ensure our manufacturing partners are ISO certified?
We do thorough checks of every manufacturing partner (MP) during the initial onboarding process and perform audits on processes and certifications every two years. To source parts from certified MPs, you can indicate these requirements on the platform or contact sales@hubs.com . We’ll match your designs with the right supplier.
How does Hubs protect data and intellectual property?
Our platform is secure and encrypted to ensure that customer data and interactions with suppliers are all protected. All digital models and drawings are safely stored on AWS servers, located in Europe. MPs must sign our Manufacturing Partner Agreement as part of their onboarding, which contractually obligates them to keep customer data confidential. Our General Terms of Sale prohibit orders that misappropriate or infringe on copyrights, patents, design rights, trademarks, trade secrets and other IP rights.
What happens if a part doesn’t meet your specifications?
One of the reasons engineers use Hubs is that we take on all the risks for you. If your parts aren’t up to spec, you can file a dispute claim and we’ll remake your components or refund your order. For more detail on how we handle disputes, you can contact our Customer Success Team. At the same time, we complete non-conformity reports for parts that don’t meet all requirements, with follow-up with manufacturers including root cause analysis and rapid corrective actions.
How do I request materials not listed on the site or platform?
If you want to get parts in specialized materials that aren’t listed on our site or platform, you can send a request to your account manager or contact sales@hubs.com . Our supplier network has access to a huge range of materials, so most of the time we are able to find a manufacturing partner to fulfill your request.
Put your automotive parts into production today.
